查看: 608|回复: 0
"重见天日”福特F100优雅气质改装气动避震打造属于自己的低趴姿态
发表于 2021-4-12 15:47:03 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
"See the sun again" Ford F100 elegant temperament refits pneumatic shock absorber to create its own low lying posture
改装车一直以来是顶级汽车发烧友的日常。随着对爱车的憧憬想象,逐步添加适配的套件,酷炫的外观装饰等,直到达到心中预期。这种喜欢不是常人可以理解的,很多时候改装的费用远远超过汽车本身的价值。
日前,一辆以1954年福特F100为基础进行重新设计改装,这辆以改装气动避震的方式重获新生,
Refitting cars has always been the daily routine of top car enthusiasts. With the vision and imagination of your car, gradually add matching kits, cool appearance decoration, etc., until you reach your expectations. This kind of liking is not understandable by ordinary people. Most of the time, the cost of refitting far exceeds the value of the car itself.
A few days ago, a car was redesigned and refitted based on the 1954 Ford F100. This car was reborn by refitting the pneumatic shock absorber,
它们不仅可以跑,而且跑的可以很精彩!不然怎么能叫“贴地飞行”呢!
The low lying posture that can be seen everywhere in life also makes many laymen have doubts Is it easy to run when the car is so low? Do you dare to run like this!They can not only run, but also run wonderfully!
