查看: 578|回复: 0
宝马1系改装低姿态气动避震的魅力能让你与众不同
发表于 2021-4-12 14:38:19 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
The charm of BMW 1 Series modified low profile pneumatic shock absorber can make you different
宝马1系是宝马汽车公司的车型系列,2015年,改款宝马1系在日内瓦车展亮相,这是宝马1系换代前最后一次改款,下一代1系将不再使用后驱,而采用宝马UKL前驱平台,变为前驱车。
BMW 1 series is the model series of BMW. In 2015, the modified BMW 1 series appeared at Geneva auto show, which is the last modification before the replacement of BMW 1 series. The next generation 1 series will no longer use the rear drive, but will use the BMW UKL front drive platform to change into the front drive.
From the first time I saw the car refitted by pneumatic shock absorber to now, I can't extricate myself from it. I have also experienced a lot of twists and turns! Also learned a lot about pneumatic shock absorption refit knowledge!
