查看: 524|回复: 0
丰田雷凌气动避震低姿态提升颜值利器改装分享
发表于 2021-4-11 14:58:15 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Toyota leiling pneumatic shock absorber low profile upgrade sharp tool refit share
雷凌由丰田a级车美版车型打造而成。外观凌厉的美版车型在北美已畅销多年,销量长期高居a级车市场销量榜首,而雷凌正是继承了这一车型的冠军基因,具有极高的品质基础。
Leiling is made of Toyota A-class cars and American models. The American model with sharp appearance has been popular in North America for many years, and its sales volume has long been the first in the A-class car market. Leiling inherits the champion gene of this model and has a very high quality foundation.
HellaFlush已经成为了一个国际化的改装车的外观潮流,越来越流行,越来越被大众所接受,无论类型车种贫富贵贱,HellaFlush已经趋向为一种品味的认证。让我们一起来欣赏一下丰田雷凌改装气动避震悬挂的魅力效果案例!
Hellaflush has become an international appearance trend of refitted cars, more and more popular, more and more accepted by the public, regardless of the type of car, hellaflush has become a kind of taste certification. Let's enjoy the charming effect of Toyota leiling modified pneumatic suspension!
HellaFlush的主要特征:
The main features of hellaflush are as follows:
1. The central idea of hellaflush is offset is everything. The wheel hub uses an offset value that is more stretched than the normal value, so that the wheel hub is beyond the coverage of the body fender.
2. The distance between the wheel eyebrow and the wheel hub should be as small as possible. To complete this task, the car body should be lowered to a height that does not conform to the daily use, so that some HF style cars can't drive at all, so they have to use a trailer to pull the orz. As for how to lower the car body, there is no standard. Pneumatic shock absorbers, twisted teeth shock absorbers, short springs, or even modified sheep horns, you can do anything to achieve your goal.
3. As a result of the first two points, if the tire wants not to be rubbed and burst by the fender, it must use a specification narrower than the width of the wheel hub, so that the edge of the tire can be retracted so that it can be completely hidden in the fender. Of course, the fender can also be rolled in or expanded to a certain extent according to the protruding degree of the wheel hub.
4. If you want to have more attitude than attitude, you can't take the normal road for the inclination value of the tire. Take off at minus 2 degrees (that is, the upper part of the track is narrow and the lower part is wide). The method can be to adjust the inclination rocker arm, gasket and change the sheep's horn. In a word, we can't see eye to eye with normal people.
5. Tire stretch refers to the effect of the narrow tire installed on the ultra wide wheel hub. It's not easy to achieve this effect. Choosing a variety of tires should be strictly calculated according to the width of the wheel hub. Because, too wide hub with a narrow tire, when the tire inflation may dislocation, so can let the tire according to the correct position taut on the hub depends on the technician's modification level.
