查看: 479|回复: 0
大众迈腾改装AIRBFT空气避震空气悬挂完美姿态
发表于 2021-4-11 14:21:31 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Volkswagen maiteng modified airbft air shock absorber air suspension perfect posture
大众迈腾源自和帕萨特B6关系紧密的FutureB6,这也是一汽-大众建厂以来将要生产和销售的第一款B级轿车。据一汽-大众解释,“迈”寓意自信、果决、动感;“腾”表示腾飞、超越、激情。
从B6开始,最新的大众B级车开始在一汽-大众生产,也就是Magotan迈腾系列。2010年的巴黎车展,大众第七代B级车正式亮相。2011年B7继续由一汽-大众引进国内,并延续命名为Magotan迈腾,为了满足消费者对舒适性的需求,B7还进行原生加长,媒体称为迈腾B7L,即全新迈腾。
Volkswagen maiteng comes from futureb6, which is closely related to Passat B6. It is also the first B-class car to be produced and sold by FAW Volkswagen since its establishment. According to FAW-VW, "Mai" means self-confidence, decisive and dynamic; "Teng" means taking off, surpassing and passion.
Starting from B6, the latest VW B-class cars are produced in FAW Volkswagen, namely MAGOTAN maiteng series. At the 2010 Paris auto show, Volkswagen's seventh generation B-class car officially appeared. In 2011, B7 continued to be introduced into China by FAW-VW, and continued to be named MAGOTAN maiteng. In order to meet the needs of consumers for comfort, B7 also carried out original lengthening, and the media called it maiteng b7l, that is, the new maiteng.
气动避震在国内虽然已经发展了几年的时间,但是对于很多车友来说还是一个未知的产品,没有见过,不知道改装后的效果如何,今天给大家分享一下大众迈腾改装AIRBFT气动避震低趴效果,答疑解惑!
Although pneumatic shock absorber has been developed for several years in China, it is still an unknown product for many riders. I haven't seen it before, and I don't know the effect after modification. Today, I'd like to share with you the effect of Volkswagen maiteng's modification of airbft pneumatic shock absorber, and answer questions!
The refitting of automobile chassis has a large proportion in the refitting industry. The chassis system of the original car can't meet the needs of the players now. Refitting is imperative. In recent years, the refitting of twisted tooth shock absorber is the mainstream choice of the players. It not only reduces the body, increases the aesthetic feeling, but also improves the vehicle control. However, the hardness is not acceptable to ordinary people. The rotten road makes the twisted tooth party miserable. Now it's very angry The emergence of dynamic shock absorbers makes the players who play with twisted teeth see a new dawn. The low lying effect when parking, and the car body can be raised when driving. It's really cool to lift at will. If the adjustment is good, the comfort is a little better than the tooth twisting. Now it has become a trend of chassis suspension modification. If the stability and comfort are better, it will become the most popular modification project in the future!
