查看: 391|回复: 0
斯柯达明锐改装气动悬挂展现醉美低趴姿态
发表于 2021-4-9 16:01:27 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
斯柯达明锐改装气动悬挂展现醉美低趴姿态
Skoda Mingrui refits pneumatic suspension to show zuimei's low posture
斯柯达明锐作为上汽大众斯柯达品牌的第一款轿车,是与欧洲同步的先进车型,并根据中国的情况进行了大量的本土化改进,于2007年6月6日在国内成功上市。
明锐秉承了斯柯达百年的悠久造车历史以及德国大众集团领先的造车技术,汇集众多国内领先的汽车技术和装备,成为中国同级别车型中最具竞争力的轿车之一。
Skoda Mingrui, as the first car of Skoda brand of SAIC Volkswagen, is an advanced model synchronized with Europe, and has made a lot of localization improvements according to China's situation. It was successfully launched in China on June 6, 2007.
Mingrui inherits Skoda's 100 year long car making history and the leading car making technology of German Volkswagen Group, and brings together many domestic leading automobile technologies and equipment to become one of the most competitive cars of the same class in China.
对于外观控来说,低趴范儿是改装车的首选之一,降低的车身高度,让视觉冲击力直线飙升,快“吃”进车身的轮毂造型,也能让每一个车迷热血沸腾。
斯柯达明锐气动避震升级空气避震悬挂采用的是AIRBFT空气避震系统,具有三段记忆和四轮独立功能,目前是世界上最顶级的避震系统,质量稳定,做工完美,低趴灵魂的缔造者,深受广大趴迷的痴爱。
For the appearance control, the low lying style is one of the first choices of refitted cars. The reduced body height makes the visual impact soar. It can quickly "eat" into the hub shape of the body, and also make every car fan excited.
Skoda Mingrui pneumatic shock absorption upgrade air shock absorption suspension adopts airbft air shock absorption system, which has three sections of memory and four wheels of independent function. At present, Skoda Mingrui is the world's top shock absorption system with stable quality and perfect workmanship. It is the founder of low lying soul and deeply loved by the majority of fans.
