查看: 567|回复: 0
感谢兄弟分享奔驰E W213改装AIRBFT气动避震低姿态
发表于 2021-4-9 15:22:10 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Thank you for sharing the low profile of Mercedes Benz e w213 modified airbft pneumatic shock absorber
奔驰E,是德国梅赛德斯奔驰汽车公司生产的高档汽车。用功扎实,做工精细,奔驰E级车内所营造出的稳重豪华氛围很对商务人士的口味。
奔驰E级轿车是奔驰开发出的介于C级与S级之间的一款中大型高端商务轿车,跑车,旅行车,公认E级车的鼻祖是1947年的奔驰170。
Mercedes Benz e is a high-end car produced by German Mercedes Benz automobile company. Hard working and fine workmanship, the stable and luxurious atmosphere created by Mercedes Benz E-class car is very good for business people.
Mercedes Benz E-class car is a large and medium-sized high-end business car, sports car and station wagon developed by Mercedes Benz between C-class and S-class. It is recognized that the originator of E-class car is Mercedes Benz 170 in 1947.
To pursue the dream in your heart is like seeing the girl you like. You can't restrain the impulse. So is HF style pneumatic shock absorber. The moment you lie down is so beautiful. The impulse in your heart can't be controlled like sneezing! Too many fans of pneumatic shock absorbers are only interested in hiding wheels, trimming and leveling, but the hard tube link of trunk modeling is also an art! The essence of art is taste, persistence, eternity, wisdom, painstaking efforts... Understand it, love it... Respect our spirit!
正所谓一低遮百丑,这几年HF改装火遍大街小巷,气动减震也是一夜变身改装界网红
As the saying goes, "one low covers all the ugly things." in recent years, HF refitting has become popular all over the streets, and pneumatic shock absorbers have become popular in refitting industry overnight
So what is it? In fact, it is a device that can control the air pressure and change the height of the car. It is similar to the legendary active body control system (ABC), but its working medium is gas. Generally speaking, it is a set of things as shown in the figure below, including elastic rubber airbag shock absorber, air pressure control system, trunk air tank and electronic control system. It is actually similar to air shock absorber The principle is very similar to the common shock absorber, coil spring + shock absorber, except that by changing the volume of the air chamber (up and down direction), the distance between the car body and the ground can be adjusted, and the soft and hard characteristics can be changed to a certain extent. In addition, the size of the vent hole of the shock absorber can be changed by the motor, so as to adjust the damping force of the shock absorber. Therefore, the air shock absorber can often provide better performance Performance, huh! So confident!
