查看: 556|回复: 0
丰田埃尔法改装气动避震不同凡响的姿态魅力
发表于 2021-4-9 15:12:37 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Toyota Erfa refitted pneumatic shock absorber, extraordinary posture Charm
埃尔法(Alphard)是丰田应对日产Elgrand而开发的豪华MPV,采用了Previa的底盘加以改进而成。 第一代埃尔法于2002年诞生,动力有2.4升和3.0升两款发动机,都可选装四驱系统。
2008年埃尔法更新换代,为了对抗宿敌Elgrand,丰田同时推出了姐妹车Vellfire,主打年轻运动风格,但是和Elgrand相比还是略显保守。
Alphard is a luxury MPV developed by Toyota in response to Nissan elgrand, which is improved by the chassis of previa. The first generation of ELFA was born in 2002. It is powered by 2.4-liter and 3.0-liter engines, and can be equipped with four-wheel drive system.
In 2008, ELFA was upgraded. In order to fight against elgrand, Toyota also launched Vellfire, a sister car, which focuses on young sports style, but is slightly conservative compared with elgrand.
丰田埃尔法豪华商务车,移动的大面包,这款车玩改装肯定属于另类,但是冷门也会有爆款出现,国内也有几台改的非常不错的埃尔法,有兴趣的人可以欣赏一下,今天这台埃尔法 ,安装AIRBFT气动避震悬挂套件,玩姿态的同时提升一些舒适何乐而不为!
Toyota Erfa luxury business car, mobile bread, this car play refit certainly belongs to the alternative, but there will be popular, there are also several domestic very good Erfa, interested people can enjoy it, today's Erfa, install airbft pneumatic suspension kit, play posture at the same time improve some comfort, why not!
