查看: 454|回复: 0
大众CC改装AIRBFT气动避震难以抗拒的魅力
发表于 2021-4-9 14:57:47 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
The irresistible charm of Volkswagen CC modified airbft pneumatic shock absorber
一汽-大众CC是一汽-大众旗下一款运动型的轿车。
一汽-大众CC将轿车的稳定性与跑车的灵敏度结合。它采用4门无框设计,内饰具有运动风格,延续了大众汽车商务轿车系列车型的风格,真皮跑车座椅以及真皮智能运动型方向盘。
FAW Volkswagen CC is a sports car owned by FAW Volkswagen.
FAW Volkswagen CC combines the stability of the car with the sensitivity of the sports car. It adopts 4-door frameless design, sports style interior, continues the style of Volkswagen business car series, leather sports car seats and leather intelligent sports steering wheel.
大众CC在国内非常受欢迎,作为一款专为年轻人打造轿跑车型,大众CC的设计确实抓住了年轻人的心, 每一个细节都展现了年轻张扬的个性,最新款大众CC全新改款,有了很大的改变,依然很受年轻人喜欢,看看大众CC改装AIRBFT气动避震的低趴魅力!
VW CC is very popular in China. As a sedan car specially designed for young people, the design of VW CC really catches young people's heart. Every detail shows young and flamboyant personality. The latest VW CC is a brand-new modification, which has changed a lot and is still popular with young people. Take a look at the low lying charm of VW CC refitting airbft pneumatic shock absorber!
The refitting of automobile chassis has a large proportion in the refitting industry. The chassis system of the original car can't meet the needs of the players now. Refitting is imperative. In recent years, the refitting of twisted tooth shock absorber is the mainstream choice of the players. It not only reduces the body, increases the aesthetic feeling, but also improves the vehicle control. However, the hardness is not acceptable to ordinary people. The rotten road makes the twisted tooth party miserable. Now it's very angry The emergence of dynamic shock absorbers makes the players who play with twisted teeth see a new dawn. The low lying effect when parking, and the car body can be raised when driving. It's really cool to lift at will. If the adjustment is good, the comfort is a little better than the tooth twisting. Now it has become a trend of chassis suspension modification. If the stability and comfort are better, it will become the most popular modification project in the future!
