查看: 440|回复: 0
迈腾旅行版改装气动避震秀出不一样的人生姿态
发表于 2021-4-7 15:28:37 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Maiteng travel version modified pneumatic shock absorber shows a different attitude of life
迈腾四驱旅行版在2012年9月1日成都车展正式上市。本次上市的共有两款车型,具体为2.0TSI舒适版36.18万元,2.0TSI豪华版41.21万元。该车在迈腾旅行版的基础上增添了新的车身套件,配备大众4MOTION全轮驱动系统。
Maiteng 4WD travel version was officially launched in Chengdu auto show on September 1, 2012. The total price of TSI luxury model is RMB 20.412 million, and the total price of TSI luxury model is RMB 18.412 million. On the basis of the maiteng travel version, the car has added a new body kit, equipped with Volkswagen 4MOTION all wheel drive system.
大众迈腾作为国内随处可见的B级车,一直以来都给人一种沉稳、低调的形象,不过这样一款车型如果遇到现在最流行的低趴改装风格会有什么效果呢?一起来看迈腾旅行版改装气动避震案例。
As a B-class car that can be seen everywhere in China, Volkswagen maiteng has always given people a calm and low-key image. However, if such a model meets the most popular low lying refitting style, what effect will it have? Let's take a look at the refitting case of maiteng travel version for pneumatic shock absorption.
3: Responsible installation and modification shop, handling every detail, checking before delivery, air leakage, loose abnormal noise, damping height!
4: Before refitting, what you need, how you want to play, whether you want the effect after installation, and whether you have the convenience in the process of use
