查看: 633|回复: 1
奥迪A3改装气压悬挂AIRBFTHF风格低趴姿态进化之路
发表于 2021-4-7 14:13:30 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Audi A3 modified pneumatic suspension airbfthf style low prone posture evolution Road
奥迪A3是奥迪出品的一款轿车产品,奥迪A3底盘前悬架为麦弗逊式,后桥为扭转、曲柄式结构带分开布置的弹簧和减振器,除了操纵性极佳外,后悬架布置的空间利用率也很高,因此载货面积在同级车中出类拔萃。所有A3系列车型,前后制动均为盘式,前制动带通风槽。
Audi A3 is a car product produced by Audi. The front suspension of Audi A3 chassis is MacPherson type, and the rear axle is torsion and crank type structure with separately arranged springs and shock absorbers. In addition to excellent maneuverability, the space utilization rate of rear suspension layout is also very high, so the carrying area is outstanding among the cars of the same class. For all A3 series vehicles, the front and rear brakes are disc type, and the front brake is equipped with ventilation slot.
在汽车圈内一直有一句话,“一低遮百丑。”这么一句名言。哪怕再不好看的车,只要车身降低下来,绝对能令颜值提高不少(超跑好看吗?超跑都低)。那么作为具有超跑颜值的一台奥迪A3,经过AIRBFT气动避震的加持,将车身姿态降到了最低,既能提高颜值,又能提升操控的改装, 何乐而不为呢?
There has always been a saying in the car circle, "a low cover a hundred ugly." Such a famous saying. Even if the car is no longer good-looking, as long as the body is lowered, it can definitely improve the appearance of the car? The super run is low. So, as an Audi A3 with super running appearance, after the blessing of airbft pneumatic shock absorption, the body posture is reduced to the lowest, which can not only improve the appearance, but also improve the control of the refit. Why not?
发表于 2023-2-9 17:10:58 | 只看该作者
漂亮
