查看: 545|回复: 0
BENZ-CLA改装气动避震悬挂 姿态魅力从低趴路线走起
发表于 2021-4-7 13:27:41 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Benz-cla modified pneumatic suspension posture charm from low lying route
CLA是德国戴姆勒集团旗下品牌梅赛德斯-奔驰推出的一款入门级轿跑车,造型前卫。其前身的概念车型CSC发布于2012年北京车展 ,这款奔驰寄予厚望的车型在2013年初的北美车展上已经正式发布   ,定位是紧凑型级四门轿跑车。它与奔驰B级、新款奔驰A级一样,源自于奔驰MFA平台(横置发动机前驱平台);与老大哥奔驰CLS级一样拥有优雅的“溜背”造型,整个外形可谓是动感与优雅兼备;它有多款增压发动机可选,可以选装AMG运动套件,甚至可以选装4MATIC四驱系统。可见,在它身上有很多值得我们期待的。
CLA is an entry-level coupe launched by Mercedes Benz, a brand of Daimler group in Germany. Its predecessor's concept model CSC was released in 2012 Beijing auto show. This Mercedes Benz model with high hopes has been officially released at the North American auto show in early 2013. It is positioned as a compact four door coupe. Like the Mercedes Benz B-class and the new Mercedes Benz A-class, it comes from the Mercedes Benz MFA platform (horizontal engine front drive platform); like the big brother Mercedes Benz CLS class, it has an elegant "sliding back" shape, which can be described as both dynamic and elegant; it has a variety of supercharged engines to choose from, including AMG sports kit, and even 4matic four-wheel drive system. It can be seen that there are many things we should look forward to in it.
从第一次看到气动避震改装的车子到现在深深陷入其中不能自拔,也是经历了很多的曲折!也学习到了不少关于气动避震改装的知识!我们今天这台奔驰CLA作为最小的一款轿跑车车型,外观设计时尚个性,改装走姿态路线一定是没错的,接下来我们一起欣赏 BENZ-CLA改装气动避震低姿态 !
From the first time I saw the car refitted by pneumatic shock absorber to now, I can't extricate myself from it. I have also experienced a lot of twists and turns! Also learned a lot about pneumatic shock absorption refit knowledge! Today's Mercedes Benz CLA, as the smallest coupe model, has fashionable appearance design and personality. It must be right to refit and take a posture route. Next, let's enjoy the refitting of benz-cla with pneumatic shock absorber and low posture!
AIRBFT,相对于操控来说,那就它是一个四轮独立的水平记忆气动悬挂系统。何为四轮独立?就是相对于一些前后独立(我以前开始玩气动悬挂时就用过)的气动悬挂来说,就是每一个避震上的气囊都是单独一个电脑单元控制,单独的电磁阀控制,不会类似前后独立的系统一样两支避震的空气是流通的。这样就首先确保了每支避震确立了自己的独立工作,不会因为车身转向时的压力而把气压流通到不受压的避震气囊里面而产生一边高一边低的情况。水平记忆是一个气动悬挂系统的突破点,打破了老套的气压感应记忆,引入全新的,不会因为车辆载重之后导致记忆不准确的缺点,不管是高速过弯时车辆受力侧产生的压力还是载人后受重的情况下都可以稳定保持避震原先记忆的高度。
Airbft, relative to the control, is a four-wheel independent horizontal memory pneumatic suspension system. What is four rounds of independence? Compared with some front and rear independent pneumatic suspensions (which I used when I started playing pneumatic suspensions before), the air bag on each shock absorber is controlled by a separate computer unit and a separate solenoid valve, which is not the same as the front and rear independent systems. The air of the two shock absorbers is circulating. This first ensures that each shock absorber has established its own independent work, and will not flow the air pressure into the non pressurized shock absorber due to the pressure when the body turns, resulting in the situation of high side and low side. Horizontal memory is a breakthrough point of pneumatic suspension system, which breaks the old-fashioned air pressure induction memory and introduces a new one, which will not lead to inaccurate memory after the vehicle is loaded. Whether it is the pressure generated on the stressed side of the vehicle when cornering at high speed or the heavy load after carrying a person, it can stably maintain the original memory height of shock absorber.
