查看: 515|回复: 0
新款凯美瑞改装气动避震完美提升姿态魅力
发表于 2021-4-6 16:39:13 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
新款凯美瑞改装气动避震完美提升姿态魅力
New Camry refits pneumatic shock absorber to improve its posture charm perfectly
下面的这台丰田凯美瑞,改装了气动避震,轮毂轮胎,刹车系统,出色的外观和低趴姿态,受到了很多车友的喜欢,气动避震改装的实用性和突出的视觉效果,是当下非常流行的改装方式,在国内的大小展会或者是车友聚会,大多都是以气动避震该转的低趴姿态为主!
The following Toyota Camry is refitted with pneumatic shock absorbers, wheels, tires, braking system, excellent appearance and low prone posture, which is liked by many riders. The practicability and outstanding visual effect of pneumatic shock absorbers refitting are very popular refitting methods at present. Most of the domestic exhibitions and gatherings are based on the low prone posture of pneumatic shock absorbers Lord!
下面就来一步步的分解一下:
Installation of pneumatic shock absorber is roughly divided into four parts, that is, the installation of pneumatic shock absorber, pipeline laying, line positioning, and control system installation!
First of all, the installation of pneumatic shock absorbers. The installation of pneumatic shock absorbers is actually the same as the replacement of ordinary twisted tooth shock absorbers. Shock absorbers are all the installation positions of the original vehicle. What we need to pay attention to is to calculate the maximum and minimum range required by the owner according to the shock absorbers' journey, so as to adjust the height of the throttle shock absorbers. In addition, there is the reserved position of the air pipe, which is generally on the inside Yes, the rest is to follow the normal shock absorption installation steps.
Pipeline laying, pipeline laying is quite time-consuming work, each installation master's method and idea are different, but to follow a principle is to avoid the possible bending or vehicle driving may be pressed or ground to the gas pipe, and is far away from the exhaust, because the gas pipe material is prone to high temperature, the best way is It's going with the tubing.
It's very troublesome to move the lines along with the electrical circuits in the car. It's better not to cut off the main power line if you need to disassemble many interior parts. In addition, if there are other electrical equipment in the car, you must not share the power line to prevent mutual interference.
The installation of control system, airbft pneumatic shock absorption control system is quite simple control system, but want to perfect the installation or must have some experience, there are many details need to pay attention to, especially each joint and gas pipe and gas hole screw tooth connection, should be carefully installed, gas hole and joint screw tooth connection must be sealed, should be in case of leakage It's very troublesome to check and test the gas condition again. Try to do it in one step.
