查看: 558|回复: 0
奥迪A3改装气动避震悬挂姿态的极致升华
发表于 2021-4-6 15:56:01 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
奥迪A3改装气动避震悬挂姿态的极致升华
The ultimate sublimation of Audi A3 modified pneumatic suspension posture
奥迪A3是奥迪出品的一款轿车产品,基于大众MQB平台研发,车身采用轻量化设计和铝制材料,动力上搭载1.4TFSI和1.8TFSI等多款发动机。
奥迪A3底盘前悬架为麦弗逊式,后桥为扭转、曲柄式结构带分开布置的弹簧和减振器,除了操纵性极佳外,后悬架布置的空间利用率也很高,因此载货面积在同级车中出类拔萃。所有A3系列车型,前后制动均为盘式,前制动带通风槽。
Audi A3 is a car product produced by Audi. It is developed based on the MQB platform of Volkswagen. The body is made of lightweight design and aluminum materials. It is powered by 1.4tfsi and 1.8tfsi engines.
The front suspension of Audi A3 chassis is McPherson type, and the rear axle is torsion and crank type structure with separately arranged springs and shock absorbers. In addition to excellent maneuverability, the space utilization rate of rear suspension arrangement is also very high, so the carrying area is outstanding among the cars of the same class. For all A3 series vehicles, the front and rear brakes are disc type, and the front brake is equipped with ventilation slot.
今天说道的这台奥迪A3,经过AIRBFT气动避震的加持,将车身姿态降到了最低,简直是具有超跑颜值的一台小A3,在这个拼个性,讲究颜值的今天,满大街的车子, 在加上稍微的改装,简直是完美!
Today's Audi A3, with the help of airbft pneumatic shock absorbers, has reduced the body posture to the lowest level. It's a small A3 with super running appearance. Today, with personality and beauty, cars all over the street are perfect with a little modification!
气动避震的组成部分分为控制系统和气动避震桶身两大类!
From the first time I saw the car refitted by pneumatic shock absorber to now, I can't extricate myself from it. I have also experienced a lot of twists and turns! Also learned a lot about pneumatic shock absorption refit knowledge!
The components of pneumatic shock absorber are divided into control system and pneumatic shock absorber barrel!
Let's talk about the pneumatic shock absorption control system. Now the mainstream control system is divided into two types, namely, the one with memory mode and the one without memory mode. The one with memory mode has to mention the control system of airbft first. It should be the first system to enter China. Its stability and convenience are trusted and liked by many riders! Let's talk about its function and intelligence!
There are three main options for refitting shock absorbers: competitive short spring, suit and twisted teeth. These functions are different, and the prices are quite different. The most important thing is to choose a shock absorber that suits you best. So what is the right shock absorber for you? After replacing and refitting the shock absorber, the first thing you have to bear is the loss of comfort. So if you still pursue the comfort of the vehicle, I suggest you not to replace it. If there is no problem with a little loss, replacing the set can not only improve the handling of the vehicle, but also not lose too much comfort. Because the appearance of the suit is to improve the handling performance of the vehicle on the large structure of the original shock absorber. However, there are also many shortcomings in shock absorber suits. First, the price is slightly expensive. Second, the damping and height can not be adjusted. Third, at present, the main brands of shock absorber suits are still concentrated in European cars, while Japanese car suits are not popular. However, for many senior players, shock absorbers can no longer meet their needs, so tooth twisting shock absorbers have become their first choice. In fact, the word "twisted teeth" comes from Hong Kong, China. Its real full name is height. Adjustable. Damper, which has the meaning of adjustable number of damper segments and body height. Seeing this name, I don't think I need to introduce its functions too much. It's all reflected in the name. However, Xiaobian still needs to add that although the ideal body height and handling performance can be obtained after replacing the hinged tooth shock absorber, it is built on the loss of 60% comfort, so it is best to be prepared before replacing it
