查看: 2497|回复: 0
VW-MK5改装空气避震低姿态与时尚接轨
发表于 2021-4-6 15:41:16 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Vw-mk5 modified air shock absorber, low profile and fashion
对于VW-MK5,喜欢的人说它是大众造车工艺的巅峰之作,  而我对于它的外形是有些接受不了,但不得不承认它是当时大众打造的一款非常卓越的车型,下面我就为大家介绍一款改装智能控制AIRBFT气动避震的VW-MK5,来欣赏一下吧!
For vw-mk5, people who like it say that it is the pinnacle of VW's car making technology, but I can't accept its appearance, but I have to admit that it was a very excellent model built by VW at that time. Now I'd like to introduce a vw-mk5 modified with intelligent control airbft pneumatic shock absorber. Let's enjoy it!
气动避震的组成部分为控制系统和气动避震桶身两大类!
The components of pneumatic shock absorber are control system and pneumatic shock absorber barrel!
Intelligent air replenishment and intelligent adjustment of car level: in fact, the functions of these two functions are probably the same. For example, when the car body is originally horizontal, a fat person sits in the rear seat, the height of the rear side will be reduced. At this time, the computer will detect the height change of the rear side, and will react in less than a second. The two rear airbags will inflate to maintain the height Body level!
The ignition will automatically rise to the set position height: such a function is that no matter what height you park, for example, the lowest or the highest, when you stop, get off and drive again, the system will automatically raise the car to the second gear position, that is, the normal car height! This has both advantages and disadvantages. For example, the road condition is very bad. There is no suitable parking space. When you park, you stop at the highest position. When you drive again, the system will automatically reduce. If you just park on a very high rural cement deceleration belt, it is very likely or direct bottoming! The advantage is that in a normal parking lot, the car stops to the lowest level. When you drive again, the train will automatically rise to the normal driving height at one o'clock. Think about how high the driving height is
One key to the lowest: a key, you can reduce the car to the lowest state! On the control panel, there is a one button to lower. Long press for 3 seconds, and the whole car will be in the lowest state! Why three seconds? Because this is to prevent misoperation. If your car is running, it's a terrible thing if a child or a special case accidentally touches the button with one button lowered. This design can completely avoid this situation. It doesn't matter if you accidentally touch all the buttons, as long as you don't press them for a long time!
