查看: 579|回复: 0
十代思域改装气动避震 低趴姿态完美无敌
发表于 2021-4-5 14:19:43 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
十代思域改装气动避震 低趴姿态完美无敌
Ten generations of civic refitted pneumatic shock absorber, perfect posture
改装气动避震悬挂的客户一般要求姿态也要兼顾舒适性,这样的要求可谓很难达到,因为车型不同效果肯定就会有所不同,气动避震改装主要就要为了低姿态,很多玩家只能退求其次。十代思域安装AIRBFT气压避震控制系统,  舒适性比原车好很多,开起来相当舒服,低趴效果也是相当好,绝对的改装首选,值得推荐!
Customers who refit the pneumatic suspension generally require that the posture should also take into account the comfort, which is difficult to achieve, because different models will certainly have different effects. The main purpose of refitting the pneumatic suspension is to keep a low posture, and many players can only follow suit. The 10th generation Civic is equipped with airbft pneumatic shock absorption control system. The comfort is much better than that of the original car. It's quite comfortable to drive, and the low lying effect is also quite good. It's absolutely the first choice for refitting. It's worth recommending!
AIRBFT专用气囊:
Airbft airbag:
