查看: 576|回复: 0
奥迪A3改装案气动避震悬挂姿态的极致升华
发表于 2021-4-5 13:40:37 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
The ultimate sublimation of the suspension posture of Audi A3 modified pneumatic shock absorber
运动与动态,高超的技术和高质量的诉求:从第一次驱动这款车,奥迪A3驾驶者就将它所有特性珍藏。由于它设计者十分努力地重视每个细节,这款奥迪已经可以让这款紧凑型车拥有更多的力量,同时融合了它的外观造型以及其人体工程学。
Sports and dynamics, superb technology and high quality demands: from the first time driving this car, Audi A3 drivers treasure all its features. With its designers working so hard to pay attention to every detail, Audi has been able to give this compact car more power, while integrating its appearance and ergonomics.
今天的这台奥迪A3,充满了运动的细胞 ,包括操控,动力各个方面都是相当的出色,在这个拼个性,讲究颜值的今天,满大街的车子,不改装什么时候才能也得不到关注!经过AIRBFT气动避震的加持,将车身姿态降到了最低,   简直是具有超跑颜值的一台小A3, 简直是完美!
Today's Audi A3 is full of sports cells, including control and power. It's quite outstanding in all aspects. In today's world of personality and beauty, cars on the street can't get attention without modification! After airbft pneumatic shock absorbers blessing, the body posture is reduced to the lowest, it is a super run appearance of a small A3, it is perfect!
