查看: 467|回复: 0
“魅力、刺激”丰田锐志改装气动避震 要的就是这种低趴范
发表于 2021-4-4 15:31:21 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
"Charm, stimulation" Toyoda Ruizhi refit pneumatic shock absorber is to this kind of low lying fan
MARK X国产后改名锐志(REIZ),它源于德语,是“魅力、刺激”的意思,是丰田对目标消费群体的总体特征的概念性描述。在日本MARK X是一款运动型车,而国产后,MARK X被赋予了一个响亮的中文名――锐志(Reiz),同时在德语中意为“魅力”的“Reiz”也出现在车的尾部。这款车的定位区间(功能的对手/非单纯价格)非常的大,从十几万上下的宝来,到Mazda6、天籁、奥迪A4直到宝马530i,只要和运动沾边的车,都可以看作它的对手。
Mark X was renamed Reiz after it was made in China. It originated from German and means "charm and stimulation". It is Toyota's conceptual description of the overall characteristics of the target consumer groups. In Japan, mark X is a sports car. After being made in China, mark X has been given a loud Chinese name - Reiz. At the same time, Reiz, which means "charm" in German, also appears in the rear of the car. The positioning range of this car is very large, from Bora, Mazda6, Teana, Audi A4 to BMW 530i. As long as the car is related to sports, it can be regarded as its opponent.
相信大家看到过有车子停靠在停车场,而车身离地面十分接近,心里难免会充满好奇,车子是如何做到这么低的? 原理就是车子改装了气动避震,能够自由升降车子的高度。下面就让我们一起欣赏一下丰田锐志改装气动避震后的低趴效果。
I believe you have seen a car parked in the parking lot, and the car body is very close to the ground. You will inevitably be curious. How can the car be so low? The principle is that the car is refitted with pneumatic shock absorber, which can lift the car freely. Now let's enjoy the low lying effect of Fengtian Ruizhi's modified pneumatic shock absorber.
气动避震的组成部分为控制系统和气动避震桶身两大类!
The components of pneumatic shock absorber are control system and pneumatic shock absorber barrel!
Three section memory function: the car owner can set three different height modes of high position, normal position and low position by himself, by pressing 1, 2 and 3 One click up or down to the height suitable for the current road conditions. When driving at high speed, you can go down to first gear and drive at low position. Reduce the center of gravity to enhance the stability and reduce the wind resistance of the car. You can also save fuel to a certain extent. In cities or villages, you can go up to second gear and drive at normal height. You can cope with most of the road conditions. If you encounter very bad road conditions, you can go up to third gear It's about 12 centimeters from the lowest to the highest! Three different heights of gear can be quickly switched at any time!
Intelligent air replenishment and intelligent adjustment of car level: in fact, the functions of these two functions are probably the same. For example, when the car body is originally horizontal, a fat person sits in the rear seat, the height of the rear side will be reduced. At this time, the computer will detect the height change of the rear side, and will react in less than a second. The two rear airbags will inflate to maintain the height Body level!
The ignition will automatically rise to the set position height: such a function is that no matter what height you park, for example, the lowest or the highest, when you stop, get off and drive again, the system will automatically raise the car to the second gear position, that is, the normal car height! This has both advantages and disadvantages. For example, the road condition is very bad. There is no suitable parking space. When you park, you stop at the highest position. When you drive again, the system will automatically reduce. If you just park on a very high rural cement deceleration belt, it is very likely or direct bottoming! The advantage is that in a normal parking lot, the car stops to the lowest level. When you drive again, the train will automatically rise to the normal driving height at one o'clock. Think about how high the driving height is
One key to the lowest: a key, you can reduce the car to the lowest state! On the control panel, there is a one button to lower. Long press for 3 seconds, and the whole car will be in the lowest state! Why three seconds? Because this is to prevent misoperation. If your car is running, it's a terrible thing if a child or a special case accidentally touches the button with one button lowered. This design can completely avoid this situation. It doesn't matter if you accidentally touch all the buttons, as long as you don't press them for a long time!
