查看: 451|回复: 0
别克君威升级AIRBFT气动避震套件姿态更加游刃有余
发表于 2021-4-4 15:06:00 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Buick Regal upgrade airbft pneumatic shock absorber kit, more comfortable posture
作为别克品牌最成功的战略车型之一,君威凭借潮流、动感、科技的产品形象和全面的技术实力深受用户青睐。别克君威汇聚通用汽车全球先进技术,在承袭传统优势的同时,针对新时期消费者不断提升的用车需求,以革新的产品实力带来新驾值之美,实现动感型格、驾乘品质、科技属性的再次进化。
As one of the most successful strategic models of Buick brand, Regal is favored by users with its product image and comprehensive technical strength of fashion, dynamic and technology. Buick Regal brings together the global advanced technology of general motors. While inheriting the traditional advantages, Buick Regal brings the beauty of new driving value with its innovative product strength to meet the increasing demand of consumers in the new era, and realizes the re evolution of dynamic style, driving quality and technological attributes.
俗话说“百改降为先,一低遮百丑”君威改装AIRBFT气动避震很好的应验了这一点, 避震悬挂系统的改装,在汽车的改装除了发动机改装,应该也算是个大的手术了!下面这台君威改装的是这几年比较主流的改装方式,气动避震改装低趴!
As the saying goes, "one hundred changes first, one low cover one hundred ugly" Regal refit airbft pneumatic shock absorption well fulfilled this point, the refit of shock absorption suspension system, in addition to engine refit in car refit, should also be regarded as a big operation! The following Regal refitting is the mainstream refitting method in recent years, pneumatic shock absorber refitting low prone!
首先,在更换车辆避震系统前一定要先知道更换的避震器的功能,以及你改装的需要。当然避震器的主要构成是由四个避震弹簧以及四只避震筒组合而形成,弹簧最主要的功用是用来消除行经不平路面的震动,我想这谁都知道。但许多人会问四只避震筒在车辆行进中又可以起到什么样的作用?其实避震筒的真正用途用来抑制弹簧吸震後反弹时的震荡和吸收路面冲击的能量。假如你开过避震器坏掉的车,你就可以体会车子通过每一坑洞、起伏後馀波荡漾的弹跳,而避震器正是用来抑制这样的弹跳。没有避震器将无法控制弹簧的反弹,车子遇到崎岖路面时将会产生严重的弹跳,过弯时也会因为弹簧上下的震荡而造成轮胎抓地力和循迹性的丧失,所以避震筒对车辆的操控力还是起着至关重要的作用。
First of all, be sure to know the function of the replaced shock absorber and the need of your modification before replacing the vehicle's shock absorber system. Of course, the main structure of the shock absorber is composed of four shock absorbers and four shock absorbers. The main function of the spring is to eliminate the vibration of the uneven road. I think everyone knows that. But many people will ask what role can four shock absorbers play when the vehicle is moving? In fact, the real purpose of the shock absorber is to suppress the shock when the spring rebounds after the shock absorption and absorb the energy of road impact. If you've ever driven a car with a broken shock absorber, you can experience the bouncing of the car through every hole and after the ups and downs, and the shock absorber is used to suppress such bouncing. Without the shock absorber, the rebound of the spring can not be controlled. When the car encounters a rough road, it will have a serious bounce. When it turns, it will also cause the loss of tire grip and tracking due to the vibration of the spring up and down. Therefore, the shock absorber still plays a vital role in the control of the vehicle.
