查看: 537|回复: 0
奔驰C级改装空气避震低姿态魅力迷人低趴范
发表于 2021-4-3 13:36:43 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Mercedes Benz C-class modified air shock absorber low profile charming low lying model
Many of my friends have bought their own cars. They asked me how and where to refit them. Among them, the most consulted is the modification of shock absorbers. No wonder, however, that the shock absorbers of vehicles can be regarded as the most important retrofitting for the poor. They also involve hot spots with relatively high prices. I think that if a good shock absorber system is replaced in the daily refitting of street vehicles, the refitting space will be reduced a lot, so that we can give full play to it. But how to choose a suitable shock absorber? There are many of them.
