查看: 655|回复: 0
十代思域改装了气动避震 低趴姿态完美无敌
发表于 2021-4-2 16:26:12 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
The 10th generation Civic is refitted with pneumatic shock absorber, and its low prone posture is perfect and invincible
十代思域改装气动避震低趴案例,来着AIRBFT气动避震是大家都非常熟悉的,思域外观改装低趴非常的酷炫,就像是一辆跑车
Ten generations of civic refit pneumatic shock absorber low lying case, airbft pneumatic shock absorber is very familiar to everyone, civic appearance refit low lying very cool, like a sports car
The working principle of the shock absorber is mainly used to suppress the shock of spring rebound after shock absorption and the impact from the road. When passing through uneven road, although the shock absorption spring can filter the vibration of the road, the spring itself will have reciprocating motion, and the shock absorber is used to suppress the spring jump.
The types of shock absorbers are divided from the angle of producing damping materials. There are mainly two kinds of shock absorbers: hydraulic shock absorbers and pneumatic shock absorbers.
