查看: 605|回复: 0
马自达CX-7改装气动避震低姿态魅力与时尚同行
发表于 2021-4-2 16:10:43 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Mazda CX-7 modified pneumatic shock absorber low profile charm and fashion
马自达CX-7的设计理念是“高端前沿”。据首席设计师小泉严介绍:马自达CX-7的设计目标,是将动感操控、速度型外观与大胆表现力融合为激情四溢的整体宣言。而马自达品牌传承的动感优势,为这款崭新的Crossover SUV赋予了强烈而鲜明的跑车外观特征。
The design concept of Mazda CX-7 is "high end and cutting edge". According to chief designer Yan Koizumi, the design goal of Mazda CX-7 is to integrate dynamic control, speed appearance and bold expression into a passionate overall manifesto. The dynamic advantage of Mazda brand heritage gives this brand-new crossover suv a strong and distinctive sports car appearance.
改装就是做常人不敢做,打造与众不同的风格姿态,马自达CX-7 改装AIRBFT气动避震悬挂,低姿态改装不走寻常路,让我们一起欣赏马自达CX7改装低姿态的魅力!
Refit is to do ordinary people dare not do, to create a unique style and posture, Mazda CX-7 refit airbft pneumatic suspension, low-profile refit unusual road, let's enjoy the charm of Mazda cx7 refit low-profile!
