查看: 558|回复: 0
LEXUS LS430改装气动避震 见证改装的完美蜕变
发表于 2021-4-2 14:53:09 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Lexus ls430 refitting pneumatic shock absorber witness the perfect transformation of refitting
丰田汽车公司与丰田汽车(中国)有限公司计划在中国市场上率先推出第三代豪华轿车的旗舰之作──LexusLS430超级豪华轿车,实践车迷对完美豪华轿车的种种想像。新车型在6月6-12日在中国国际展览中心举行的“第六届北京国际汽车工业展览会”上进行全国公开首展。
Toyota Motor Company and Toyota Motor (China) Co., Ltd. plan to launch the flagship of the third generation of luxury cars in the Chinese market - Lexus ls430 super luxury car, to practice the imagination of fans on the perfect luxury car. The new model was exhibited in the 6th Beijing International Automobile Industry Exhibition held in China International Exhibition Center from June 6 to 12.
对于LEXUS LS430的粉丝来讲,低趴也是不少人追捧的风格之一了,不一定要走浓浓的VIP风格,一套运动范的轮毂,加上一套可调高低气动减震,便可以玩转气动避震Hellaflush的最美风格改装
For fans of Lexus ls430, low lying is also one of the styles pursued by many people. You don't have to follow a strong VIP style. You can play with the most beautiful style of hellaflush with a set of sporty wheels and a set of adjustable high and low pneumatic shock absorbers
Let's break down the word hellaflush = hellaflush, which means there are two parts, one is Hella, the other is flush. Hella is the abbreviation of hell of, which means special, extraordinary, absolute and super; flush means flush. So here are two things to be very clear about:
1. The formation of hellaflush must first satisfy the requirement of flush, that is, flat wheel hub tire, and then be qualified to work hard from flush to hellaflush;
2. The body height must be as low as possible. From the side of the car, there must be no gap between the tire and the leaf plate.
气动悬架避震一直被大家误解为只会升降高度而牺牲驾驶感受的避震,其实不然。AIRBFT出品的这套气动避震并没有想象中轻飘的感觉,在直线行驶时与绞牙避震有着接近的回弹韧性,但是在弯道中则会表现出弱于绞牙避震的支撑性,不过并不会出现很夸张的侧倾。这样的行驶表现,一定会让更多的人喜欢上这种随时升降的感觉。而HellaFlush更是一种没有车型界限的改装,只要你喜欢都可以创造出独一无二的你!
Pneumatic suspension has always been misunderstood as a kind of shock absorber which can only raise or lower the height at the expense of driving experience. In fact, it is not. Airbft's pneumatic shock absorbers don't have the lightness in imagination. They have similar resilience when driving in a straight line, but they will show less support than those in a curve, but they won't show exaggerated roll. Such driving performance will surely make more people like the feeling of lifting at any time. Hellaflush is a kind of refit without the limitation of vehicle model. As long as you like it, you can create a unique you!
