查看: 598|回复: 0
Honda civic改装气动避震!低趴效果一流!
发表于 2021-4-2 14:14:33 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Honda Civic modified pneumatic shock absorber! The effect of low lying is first-class!
Honda Civic has launched a variety of models to cater to the tastes of consumers in different countries, including three door hatchback hatchback hatchback, coupe, hybrid and five door saloon. Honda Civic, which is listed in China, and Dongfeng Honda's existing model Honda CR-V come from the same production platform. The two cars use the same chassis, which provides a prerequisite for Honda Civic to be made in China. After 40 years of experience and continuous evolution in 10 generations of interpretation, today's 10th generation Civic (Civic) condenses many advanced technologies of the leading era, presenting you with a great sense of future and technology.
There has always been a saying in the car circle, "a low cover a hundred ugly." Such a famous saying. Even if the car is no longer good-looking, as long as the body is lowered, it can definitely improve the appearance of the car? The super run is low. So as a modification that can improve the appearance and control, how to modify the shock absorber?
First of all, airbft's control memory mode and control memory mode are the two most popular modes in the United States! Let's talk about its function and intelligence!
