查看: 487|回复: 0
Toyota-wish改装气动避震打造属于自己的低趴姿态
发表于 2021-4-1 15:22:55 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Toyota wish refits pneumatic shock absorber to create its own low prone posture
丰田Wish是丰田旗下的一款商务车,采用了2.0L发动机,满足商务接待的需求。
丰田Wish是一款7座的MPV车型,2003年上市以来,在日本、中国台湾等国家、地区广受欢迎。其第二代产品已在中国台湾地区投产并上市,由于新一代丰田Wish与Corlla共用平台,考虑成本控制与生产效益,Wish最有可能被一汽丰田国产。据传闻,一汽丰田即将投产的国产版Wish,与台湾地区生产的版本相同。车身尺寸为4625×1720×1590mm,轴距为2750mm。一汽丰田Wish的主要竞争对手将是进口马自达5、长安福特S-Max、广汽本田奥德赛、上海大众途安等车型。
Toyota wish is a business car owned by Toyota, which adopts 2.0L engine to meet the needs of business reception.
Toyota wish is a seven seat MPV model. Since it was launched in 2003, it has been popular in Japan, Taiwan and other countries and regions. Its second-generation products have been put into production and listed in Taiwan, China. As the new generation of Toyota wish and corrla share the same platform, considering cost control and production efficiency, wish is most likely to be made in China by FAW Toyota. According to rumors, FAW Toyota's upcoming domestic version of wish is the same as that produced in Taiwan. The body size is 4625 × 1720 × 1590 mm, and the wheelbase is 2750 mm. The main competitors of FAW Toyota wish will be Mazda 5, Changan Ford S-MAX, GAC Honda Odyssey and Shanghai Volkswagen Touran.
它们不仅可以跑,而且跑的可以很精彩!
不然怎么能叫“贴地飞行”呢!
The refitting of automobile chassis has a large proportion in the refitting industry. The chassis system of the original car can't meet the needs of the players now. Refitting is imperative. In recent years, the refitting of twisted tooth shock absorber is the mainstream choice of the players. It not only reduces the body, increases the aesthetic feeling, but also improves the vehicle control. However, the hardness is not acceptable to ordinary people. The rotten road makes the twisted tooth party miserable. Now it's very angry The emergence of dynamic shock absorbers makes the players who play with twisted teeth see a new dawn. The low lying effect when parking, and the car body can be raised when driving. It's really cool to lift at will. If the adjustment is good, the comfort is a little better than the tooth twisting. Now it has become a trend of chassis suspension modification. If the stability and comfort are better, it will become the most popular modification project in the future!
