查看: 460|回复: 0
TOYOTA ALPHARD改装AIRBFT气动避震控制系统 完美展现个性低趴姿态
发表于 2021-4-1 15:08:00 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Toyota alpha refits airbft pneumatic shock absorption control system, perfectly shows personality low prone posture
埃尔法(Alphard)是丰田应对日产Elgrand而开发的豪华MPV,采用了Previa的底盘加以改进而成。 第一代埃尔法于2002年诞生,动力有2.4升和3.0升两款发动机,都可选装四驱系统。
2008年埃尔法更新换代,为了对抗宿敌Elgrand,丰田同时推出了姐妹车Vellfire,主打年轻运动风格,但是和Elgrand相比还是略
Alphard is a luxury MPV developed by Toyota in response to Nissan elgrand, which is improved by the chassis of previa. The first generation of ELFA was born in 2002. It is powered by 2.4-liter and 3.0-liter engines, and can be equipped with four-wheel drive system.
In 2008, ELFA was upgraded. In order to fight against elgrand, Toyota also launched Vellfire, a sister car, which focuses on young sports style, but is slightly conservative compared with elgrand.
丰田埃尔法豪华商务车, 这款车玩改装肯定属于另类,但是冷门也会有爆款出现,国内也有几台改的非常不错的埃尔法,有兴趣的人可以欣赏一下,今天这台安装AIRBFT气动避震悬挂套件,玩姿态的同时提升一些舒适何乐而不为!
Toyota Erfa luxury business car, this car must be an alternative, but there will be popular models. There are also several very good Erfa in China. People who are interested can enjoy it. Today, this one is equipped with airbft pneumatic suspension kit, which can improve some comfort while playing posture. Why not!
在改装界不论从早前上市国产第一代的GD车型,还是现在的GE车型都是一台深受大家喜爱的热门小车,改装风格更是从性能范儿、VIP到现如今大热的HellaFlush都是一把好手。提到HellaFlush,这种主要以降低车身和轮毂、轮胎外延与轮眉外延齐边的感觉为主的改装,同样是近年来十分受欢迎的一种比较“外貌协会”的风格,由于其对车型、颜色等并不像传统改装风格那样有较多限制,因此深受全球很多年轻人的追捧,以此彰显自己的个性与时尚品味。
In the field of refitting, both the first generation GD model and the current Ge model are popular cars, and the refitting style is good from performance and VIP to Hella flush. When it comes to hellaflush, this kind of refitting mainly reduces the feeling that the car body and wheel hub, tire extension and wheel eyebrow extension are flush with each other. It is also a popular "appearance Association" style in recent years. Because it does not have more restrictions on the car model and color than the traditional refitting style, it is sought after by many young people all over the world to show their personality And fashion taste.
既然是HellaFlush首先就是要降低身段,将原本高高在上的车身变成趴在地下最好。而趴在地下无非两种:绞牙避震和气动悬挂避震,而绞牙避震虽然能够降低车身但是想要达到气动悬架的效果还是有不小难度,更何况绞牙避震对于现如今中国道路遍地的“炮弹坑”来讲实在是一种煎熬。至于气动则可以通过压缩机将压缩空气输送到每个避震的气囊中来进行高低调节,以达到趴在地上的效果。气动悬挂更是HellaFlush拥簇者们的最爱,所以 AIRBFT出品的气动避震替换了原有的避震顺利进入低趴一族!
Since it's Hella flush, the first thing to do is to lower the body height, and turn the original high body into the best one to lie on the ground. There are no more than two ways to lie in the ground: tooth suspension and pneumatic suspension. Although tooth suspension can reduce the car body, it is still difficult to achieve the effect of pneumatic suspension. What's more, tooth suspension is a kind of suffering for the "Bomb pit" everywhere in China today. As for pneumatics, the compressed air can be delivered to each shock absorber air bag through the compressor for height adjustment, so as to achieve the effect of lying on the ground. Pneumatic suspension is the favorite of hellaflush fans, so airbft pneumatic shock absorbers replace the original shock absorbers and smoothly enter the low lying group!
气动悬架避震一直被大家误解为只会升降高度而牺牲驾驶感受的避震,其实不然。AIRBFT出品的这套气动避震并没有想象中轻飘的感觉,在直线行驶时与绞牙避震有着接近的回弹韧性,但是在弯道中则会表现出弱于绞牙避震的支撑性,不过并不会出现很夸张的侧倾。这样的行驶表现,一定会让更多的人喜欢上这种随时升降的感觉。而HellaFlush更是一种没有车型界限的改装,只要你喜欢都可以创造出独一无二的你!
The shock avoidance of pneumatic suspension has been misunderstood as the shock avoidance which only can raise and fall height and sacrifice driving experience, but it is not. This aerodynamic shock proof set produced by airbft has no imaginary feeling of light floating. It has similar resilience with the cutter teeth when driving in a straight line, but it will show weak support than the tooth in the curve, but there will be no exaggeration of roll. Such driving performance, will certainly let more people like this kind of feeling of lifting at any time. Hellaflush is a kind of modification without model boundary, and you can create unique you as long as you like it!
