查看: 583|回复: 0
“国际OEM皇帝”比亚迪F0改装气动避震的HF低趴姿态展示
发表于 2021-4-1 14:27:27 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
"International OEM emperor" BYD F0 modified with pneumatic shock absorber HF low prone posture display
比亚迪F0是比亚迪公司推出的一款精品小车。比亚迪F0外观时尚,搭载比亚迪自主研发的BYD371QA高性能环保发动机,排量为1.0L,排放达到国4标准,百公里油耗仅4.2L,安全配置上,F0的双安全气囊、ABS、动力转向等一应俱全。
BYD F0 is a boutique car launched by BYD Company. BYD F0 has a fashionable appearance. It is equipped with byd371qa high-performance environmental protection engine independently developed by BYD. The displacement is 1.0L, the emission reaches the national 4 standard, and the fuel consumption per 100 km is only 4.2L. In terms of safety configuration, F0 has all kinds of double airbags, ABS, power steering, etc.
下面这台比亚迪F0,从外观的气动避震改装,再到内饰各个细节的改,真的是别出心裁,拿F0来改装的真心是少见,有些车友会说F0还改他干嘛呢?这就是爱好,改装不在乎是什么车,就是体验改装的过程和最终的结果,其中的乐趣只有真正的参与才能体会得到!
The following BYD F0, from the appearance of pneumatic shock absorbers to interior details, is really original. It's really rare to use F0 to refit. Some car friends will say why F0 is still refitted? This is a hobby. Refitting doesn't care what kind of car it is. It's just about experiencing the process and the final result of refitting. The fun can only be realized by real participation!
