查看: 631|回复: 0
荣威550改装气动避震完美诠释了颜值与内涵并存
发表于 2021-3-30 16:22:38 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Roewe 550 modified pneumatic shock absorber perfectly interprets the coexistence of appearance and connotation
全新荣威550是上汽首款基于DIS全数字模拟开发系统的车型   ,拥有领先国内、同步全球的核心技术,创新应用“D5 II数字智能化”系统。
荣威550搭载了TST 6速油冷双离合自动变速系统、Inkanet 3G数字智能网络行车系统、Start- Stop数字智能启停节能系统、EPB数字智能电子驻车系统、Configurable色彩自定义数字仪表系统。作为一部汇聚新锐科技、引领时代走向的全新车型,全新荣威550凭借全面超越同级车型的产品力,重新定义了一直由合资品牌书写的中级车标准,体现了中国自主品牌顶尖的造车实力。
The new Roewe 550 is the first model of SAIC based on DIS full digital analog development system. It has the leading domestic and global core technology and innovates the application of "d5ii digital intelligent" system.
Roewe 550 is equipped with TST 6-speed oil cooled dual clutch automatic transmission system, inkanet 3G digital intelligent network driving system, start stop digital intelligent start stop energy saving system, EPB digital intelligent electronic parking system and configurable color custom digital instrument system. As a brand-new vehicle that integrates cutting-edge technology and leads the trend of the times, the brand-new Roewe 550 redefines the intermediate vehicle standard that has been written by joint venture brands by virtue of its product strength that comprehensively surpasses the models of the same level, reflecting the top manufacturing strength of China's independent brands.
荣威550改装气动避震案例。荣威在国内市场上不是很出名,因此在大街上很少见到荣威,但是开着荣威,搭配上它完美的外观,可以说十分的上档次,这辆荣威550可谓是一个典型了。
Roewe 550 modified pneumatic shock absorber case. Roewe is not very famous in the domestic market, so we seldom see Roewe on the street. However, with the perfect appearance of Roewe, we can say that it is very high-grade. This Roewe 550 is a typical one.
Let's talk about the pneumatic shock absorption control system. Now the mainstream control system is divided into two types, namely, the one with memory mode and the one without memory mode. The one with memory mode has to mention the control system of airbft first. It should be the first system to enter China. Its stability and convenience are trusted and liked by many riders! Let's talk about its function and intelligence!
The car owner can set the normal height by three buttons: 1, 2, and 3 One click up or down to the height suitable for the current road conditions. When driving at high speed, you can go down to first gear and drive at low position. Reduce the center of gravity to enhance the stability and reduce the wind resistance of the car. You can also save fuel to a certain extent. In cities or villages, you can go up to second gear and drive at normal height. You can cope with most of the road conditions. If you encounter very bad road conditions, you can go up to third gear Gear, to improve the trafficability, from the lowest to the highest about 12 cm journey! Three different heights of gear can be quickly switched at any time!
There are three main options for refitting shock absorbers: competitive short spring, suit and twisted teeth. These functions are different, and the prices are quite different. The most important thing is to choose a shock absorber that suits you best. So what is the right shock absorber for you? After replacing and refitting the shock absorber, the first thing you have to bear is the loss of comfort. So if you still pursue the comfort of the vehicle, I suggest you not to replace it. If there is no problem with a little loss, replacing the set can not only improve the handling of the vehicle, but also not lose too much comfort. Because the appearance of the suit is to improve the handling performance of the vehicle on the large structure of the original shock absorber. However, there are also many shortcomings in shock absorber suits. First, the price is slightly expensive. Second, the damping and height can not be adjusted. Third, at present, the main brands of shock absorber suits are still concentrated in European cars, while Japanese car suits are not popular. However, for many senior players, shock absorbers can no longer meet their needs, so tooth twisting shock absorbers have become their first choice. In fact, the word "twisted teeth" comes from Hong Kong, China. Its real full name is height. Adjustable. Damper, which has the meaning of adjustable number of damper segments and body height. Seeing this name, I don't think I need to introduce its functions too much. It's all reflected in the name. However, Xiaobian still needs to add that although the ideal body height and handling performance can be obtained after replacing the hinged tooth shock absorber, it is built on the loss of 60% comfort, so it is best to be prepared before replacing it
