查看: 536|回复: 0
丰田雷凌低姿态AIRBFT气动避震施工
发表于 2021-3-30 15:53:29 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
丰田雷凌低姿态AIRBFT气动避震施工
Toyota leiling low profile airbft pneumatic shock absorption construction
雷凌由丰田a级车美版车型打造而成。外观凌厉的美版车型在北美已畅销多年,销量长期高居a级车市场销量榜首,而雷凌正是继承了这一车型的冠军基因,具有极高的品质基础。
雷凌不仅是帅气的紧凑型轿车,更在空间、油耗、操控、安全和品质方面全面领先,以‘新锐+实力’的强大优势冲击现有中级车市场,目标直指第一阵营”。
Leiling is made of Toyota A-class cars and American models. The top selling model in North America for many years is Lingmei, which is based on its high-quality appearance.
Leiling is not only a handsome compact car, but also an all-round leader in space, fuel consumption, handling, safety and quality. It has a strong advantage of "cutting edge + strength" to impact the existing intermediate car market, aiming at the first camp.
Many of my friends have bought their own cars. They asked me how and where to refit them. Among them, the most consulted is the modification of shock absorbers. No wonder, however, that the shock absorbers of vehicles can be regarded as the most important retrofitting for the poor. They also involve hot spots with relatively high prices. I think that if a good shock absorber system is replaced in the daily refitting of street vehicles, the refitting space will be reduced a lot, so that we can give full play to it. But how to choose a suitable shock absorber? There are many of them.
