查看: 519|回复: 0
本田思域改装气动避震外观低趴造型享受瞬间升降的快感
发表于 2021-3-30 15:26:17 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Honda Civic modified pneumatic shock absorber, low prone appearance, enjoy the pleasure of instant lifting
本田思域外观大气、时尚,车身线条流畅,掀背式外观与老款相比有了很大改动。东风本田思域内饰做工较为精细,设计也比较时尚,层次感较为突出,功能配置比较丰富, 内饰做工有所提升,设计层次感较强;储物空间比较合理,乘坐空间和后备箱空间都比较大;提速较快;换挡顺畅,方向盘灵活;采用ECON技术,油耗表现较为理想;售后网点覆盖全面,维修保养比较方便;安全配置比较丰富,安全性较好。
The appearance of Honda Civic is grand and fashionable with smooth body lines. Compared with the old model, the hatchback appearance has been greatly changed. Dongfeng Honda Civic interior is of fine workmanship, fashionable design, outstanding sense of hierarchy and rich functional configuration, Interior workmanship has been improved, with a strong sense of design level; storage space is reasonable, with large space for riding and trunk; speed up is fast; gear shifting is smooth, steering wheel is flexible; with econ technology, fuel consumption performance is ideal; after sales network coverage is comprehensive, maintenance is convenient; safety configuration is rich, and safety is good.
曾经有人说过,年轻的时候拥有一辆本田才不会遗憾。作为本田家族代表车, 思域让很多人找回了当年那种激情的感觉。毕竟在同级别里面,思域的改装潜力非常大,你想要竞技范儿它可以很快,你想要姿态范儿它也能变得很帅!
It has been said that when I was young, I would not regret owning a Honda. As a representative car of Honda family, civic brings back the passion of many people. After all, in the same level, Civic has great potential for modification. If you want to be competitive, it can be fast, and if you want to be posture, it can also be handsome!
The refitting of automobile chassis has a large proportion in the refitting industry. The chassis system of the original car can't meet the needs of the players now. Refitting is imperative. In recent years, the refitting of twisted tooth shock absorber is the mainstream choice of the players. It not only reduces the body, increases the aesthetic feeling, but also improves the vehicle control. However, the hardness is not acceptable to ordinary people. The rotten road makes the twisted tooth party miserable. Now it's very angry The emergence of dynamic shock absorbers makes the players who play with twisted teeth see a new dawn. The low lying effect when parking, and the car body can be raised when driving. It's really cool to lift at will. If the adjustment is good, the comfort is a little better than the tooth twisting. Now it has become a trend of chassis suspension modification. If the stability and comfort are better, it will become the most popular modification project in the future!
