查看: 556|回复: 0
赛车血统的斯巴鲁翼豹8代改装气动避震解决舒适及炫酷外观
发表于 2021-3-29 16:15:51 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
The 8-generation Subaru leopard with racing pedigree is refitted with pneumatic shock absorbers for comfort and cool appearance
斯巴鲁impreza翼豹以其卓越的性能在历届wrc世界拉力锦标赛中获得优异的成绩。量产车的设计研发与生产,也应用到了比赛中的成功经验,斯巴鲁翼豹wrx继承了纯正的赛车血统,06款第九代翼豹更是换装了2.5t发动机,并原车配备二次进气系统。
Subaru Impreza leopard has achieved outstanding results in all previous WRC World Rally championships with its excellent performance. The design, R & D and production of mass production vehicles are also applied to the successful experience of the competition. Subaru leopard WRX inherits the pure racing pedigree. The 06 ninth generation leopard is equipped with a 2.5t engine, and the original vehicle is equipped with a secondary air intake system.
下面的这台翼豹8代 厌倦了赛场,来改装了气动避震玩起了底盘的升降,说实话,一成不变的底盘高度确实是挺枯燥无味的,改装了气动避震之后可以随时的升降底盘高度,高速行驶时可以降低车身来增强稳定性,路况不好的时候可以升高车身来提高通过性,同时降低车身的低姿态也是相当的漂亮的!是一举多得的改装方案!
The next eight generations of the leopard Tired of the competition, I refitted the pneumatic shock absorber to play the chassis lifting. To tell you the truth, the unchanging chassis height is really boring. After refitting the pneumatic shock absorber, I can lift the chassis height at any time. When driving at high speed, I can lower the body to enhance stability. When the road condition is bad, I can raise the body to improve trafficability. At the same time, I can lower the low posture of the body It's quite beautiful! It's a refitting plan with more than one stone!
So what is it? In fact, it is a device that can control the air pressure and change the height of the car. It is similar to the legendary active body control system (ABC), but its working medium is gas. Generally speaking, it is a set of things as shown in the figure below, including elastic rubber airbag shock absorber, air pressure control system, trunk air tank and electronic control system. It is actually similar to air shock absorber The principle is very similar to the common shock absorber, coil spring + shock absorber, except that by changing the volume of the air chamber (up and down direction), the distance between the car body and the ground can be adjusted, and the soft and hard characteristics can be changed to a certain extent. In addition, the size of the vent hole of the shock absorber can be changed by the motor, so as to adjust the damping force of the shock absorber. Therefore, the air shock absorber can often provide better performance Performance, huh! So confident!
