查看: 593|回复: 0
“弯道之王”马自达6改装气动避震低趴姿态完美释放太漂亮了
发表于 2021-3-29 15:56:24 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
"King of curves" Mazda6 modified pneumatic shock absorber, low prone posture, perfect release, beautiful
2003年4月10日马自达6来到中国,凭借着其非凡的外观及操控性,在当年获得年度车“弯道之王”的称号,并一直保持旺销势态,其动感的内饰外形、优异的操控性、高标准的安全性、宽大的内部空间和精细的做工等,创设了21世纪中高级轿车的一个新的全球标准。
Mazda6 came to China on April 10, 2003. With its extraordinary appearance and handling, Mazda6 won the title of "king of curves" in that year, and has always maintained a prosperous sales momentum. Its dynamic interior appearance, excellent handling, high standard safety, spacious interior space and fine workmanship have created a new global standard for medium and high class cars in the 21st century.
低趴范儿”在全球已经成为一种流行趋势,深受广大改装车迷追捧,这种方式的改装在美国日本更是成为一种普遍现象,它不仅能在视觉上给人一种强烈的冲击感,而且也能充分的展现出车主的个性和独特品味。
Low lying fan'er has become a popular trend in the world, and is popular among the majority of fans of refitting cars. This way of refitting in Japan has become a common phenomenon in the United States and Japan. It can not only give people a strong sense of impact on the vision, but also fully show the owner's personality and unique taste.
The refitting of automobile chassis has a large proportion in the refitting industry. The chassis system of the original car can't meet the needs of the players now. Refitting is imperative. In recent years, the refitting of twisted tooth shock absorber is the mainstream choice of the players. It not only reduces the body, increases the aesthetic feeling, but also improves the vehicle control. However, the hardness is not acceptable to ordinary people. The rotten road makes the twisted tooth party miserable. Now it's very angry The emergence of dynamic shock absorbers makes the players who play with twisted teeth see a new dawn. The low lying effect when parking, and the car body can be raised when driving. It's really cool to lift at will. If the adjustment is good, the comfort is a little better than the tooth twisting. Now it has become a trend of chassis suspension modification. If the stability and comfort are better, it will become the most popular modification project in the future!
