查看: 572|回复: 0
雷克萨斯IS250改装气动避震 时尚大气低姿态
发表于 2021-3-29 14:42:22 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Lexus is250 refitted pneumatic shock absorber fashion atmosphere low profile
雷克萨斯IS250是一款汽车,IS系列是雷克萨斯家族中年轻而富有动感的杰出代表,自1999年诞生以来,一直肩负引领驾驶乐趣的使命。历经三代改款,全新一代IS跃然上市,专为个性时尚,向往不凡,追逐新鲜事物的运动型族悉心打造。
Lexus is250 is a car. Is series is a young and dynamic outstanding representative of the Lexus family. Since its birth in 1999, it has been shouldering the mission of leading the fun of driving. After three generations of changes, a new generation of is is has come into the market. It is specially designed for the sporty people who are fashionable, yearning for extraordinary things and chasing new things.
Let's talk about the pneumatic shock absorption control system. Now the mainstream control system is divided into two types, namely, the one with memory mode and the one without memory mode. The one with memory mode has to mention the control system of airbft first. It should be the first system to enter China. Its stability and convenience are trusted and liked by many riders! Let's talk about its function and intelligence!
There are three main options for refitting shock absorbers: competitive short spring, suit and twisted teeth. These functions are different, and the prices are quite different. The most important thing is to choose a shock absorber that suits you best. So what is the right shock absorber for you? After replacing and refitting the shock absorber, the first thing you have to bear is the loss of comfort. So if you still pursue the comfort of the vehicle, I suggest you not to replace it. If there is no problem with a little loss, replacing the set can not only improve the handling of the vehicle, but also not lose too much comfort. Because the appearance of the suit is to improve the handling performance of the vehicle on the large structure of the original shock absorber. However, there are also many shortcomings in shock absorber suits. First, the price is slightly expensive. Second, the damping and height can not be adjusted. Third, at present, the main brands of shock absorber suits are still concentrated in European cars, while Japanese car suits are not popular. However, for many senior players, shock absorbers can no longer meet their needs, so tooth twisting shock absorbers have become their first choice. In fact, the word "twisted teeth" comes from Hong Kong, China. Its real full name is height. Adjustable. Damper, which has the meaning of adjustable number of damper segments and body height. Seeing this name, I don't think I need to introduce its functions too much. It's all reflected in the name. However, Xiaobian still needs to add that although the ideal body height and handling performance can be obtained after replacing the hinged tooth shock absorber, it is built on the loss of 60% comfort, so it is best to be prepared before replacing it
