查看: 604|回复: 0
非常任性 福特野马改装气动避震大秀低趴姿态
发表于 2021-3-29 14:27:48 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Very willful Ford Mustang refits pneumatic shock absorber to show low posture
Mustang(福特野马)是美国福特汽车公司推出的2005款野马汽车,最高时速232.2公里,设计源自2003 年汽车巡回展上的概念车,野马的诞生标志着美国仅存的大马力轿车获得了重生。
2005款福特野马采用了大胆设计理念,简洁而现代的风格,是美国历史上大马力轿车的骄子。它的设计植根于对历史传统不折不扣的传承,因而才诞生了偶像级的、更具时代感的野马。它毫不客气地把传统的竞争者甩到了身后。
Mustang (Ford Mustang) is the 2005 Mustang car launched by Ford Motor Company of the United States, with the highest speed of 232.2 km / h. The design is derived from the concept car at the 2003 auto tour exhibition. The birth of Mustang marks the rebirth of the only remaining high-powered car in the United States.
The 2005 Ford Mustang, with its bold design concept, simple and modern style, is the pride of high-powered cars in American history. Its design is rooted in the heritage of historical tradition, so it gave birth to the idol level Mustang with more sense of the times. It has rudely left its traditional competitors behind.
在改装了气动避震后,更加凸显时尚炫酷范儿,在正常行驶时可以根据路面状况的不同自由选择爱车的高度,朋友聚会时一趴到底,相信会为你博得更多关注,在遇到烂路时,提高车身高度,增强车身的通过性,采用的是空气悬挂系统,是目前生产气动避震器历史最悠久的厂家,质量与稳定性更加值得你信赖
