查看: 570|回复: 0
奔驰S350改装AIRBFT气动避震悬挂打造奢华低趴魅力
发表于 2021-3-29 14:11:14 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Mercedes Benz S350 refits airbft pneumatic suspension to create luxurious low lying Charm
奔驰S作为奔驰最豪华的一款轿车,豪华性能不言而喻,但是时代的更迭更多的人喜欢外观姿态改装,奔驰S级改装AIRBFT气动避震悬挂的魅力低姿态鉴赏!As the most luxurious car of Benz, the luxury performance of Benz S is self-evident, but with the change of the times, more people like the appearance and posture modification. The charm of Benz S-class modified airbft pneumatic suspension is appreciated in a low attitude!
The special barrel body of airbft pneumatic version is produced by SF shock proof factory in Taiwan. The air-driven shock control operation center of Shanghai provides the most accurate model data, and customized the special pneumatic version barrel body. The special vehicle is guaranteed by 100%. Each model of airbft pneumatic shock proof is tested and adjusted strictly, with accurate installation position and perfect comfort. The player can do everything possible while pursuing the ultimate posture The force for you to create perfect comfort and control, so that the pneumatic shock proof is not embroidered pillow, the real practical perfect.
AIRBFT专用气囊:
Airbft airbag:
