查看: 431|回复: 0
" 低调又奢华"奥迪A4B8气动完工AIRBFT气动套件
发表于 2021-3-28 14:43:13 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
"Low profile and luxury" Audi a4b8 pneumatic complete airbft pneumatic Kit
奥迪A4(Audi A4)是由一汽大众公司制造并于2003年4月上市的一款B级车型。
作为率先引入长轴距和涡轮概念的车型,从B5到B8,A4L的销量一直经久不衰。新款A4舍弃了泪眼设计,增加了quattro四驱模式,外形更加时尚运动,动力和操控性更加出众。车型内饰做工精致,科技配置丰富,空间充裕,在B级车型中拥有较好的实用性。
Audi A4 (Audi A4) is a class B model manufactured by FAW Volkswagen and listed in April 2003.
As the first model to introduce the concept of long wheelbase and turbine, the sales volume of A4L has been lasting from B5 to B8. The new A4 abandons the tear eye design, adds Quattro four-wheel model, and makes it more fashionable in shape, more powerful and more outstanding in handling. The interior of the vehicle is exquisite, rich in technology configuration and abundant in space, and has good practicability in class B model.
奥迪A4B9的出现让很多爱改装的车友做不住了,帅气犀利的外观设计,不整一辆改改就安耐不住这个躁动的心。今天我们就来欣赏一下改装分享的奥迪A4B8改装AIRBFT气动避震的案例介绍!
The appearance of Audi a4b9 makes many car lovers who love to refit unable to do it. The handsome and sharp appearance design can't stand the restless heart without changing the whole car. Today we will enjoy the case introduction of the modified airbft pneumatic shock avoidance of Audi a4b8!
下面就来一步步的分解一下:
Installation of pneumatic shock absorber is roughly divided into four parts, that is, the installation of pneumatic shock absorber, pipeline laying, line positioning, and control system installation!
First of all, the installation of pneumatic shock absorbers. The installation of pneumatic shock absorbers is actually the same as the replacement of ordinary twisted tooth shock absorbers. Shock absorbers are all the installation positions of the original vehicle. What we need to pay attention to is to calculate the maximum and minimum range required by the owner according to the shock absorbers' journey, so as to adjust the height of the throttle shock absorbers. In addition, there is the reserved position of the air pipe, which is generally on the inside Yes, the rest is to follow the normal shock absorption installation steps.
Pipeline laying, pipeline laying is quite time-consuming work, each installation master's method and idea are different, but to follow a principle is to avoid the possible bending or vehicle driving may be pressed or ground to the gas pipe, and is far away from the exhaust, because the gas pipe material is prone to high temperature, the best way is It's going with the tubing.
It's very troublesome to move the lines along with the electrical circuits in the car. It's better not to cut off the main power line if you need to disassemble many interior parts. In addition, if there are other electrical equipment in the car, you must not share the power line to prevent mutual interference.
The installation of control system, airbft pneumatic shock absorption control system is quite simple control system, but want to perfect the installation or must have some experience, there are many details need to pay attention to, especially each joint and gas pipe and gas hole screw tooth connection, should be carefully installed, gas hole and joint screw tooth connection must be sealed, should be in case of leakage It's very troublesome to check and test the gas condition again. Try to do it in one step.
