查看: 495|回复: 0
S13 Supra indonesia 改装AIRBFT气动避震低姿态震撼来袭
发表于 2021-3-28 13:53:33 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
S13 supra Indonesia refitted airbft pneumatic shock absorbers
There has always been a saying in the car circle, "a low cover a hundred ugly." Such a famous saying. If the car's appearance is not improved, can it be even better? The super run is low. So as a modification that can improve the appearance and control, how to modify the shock absorber?
AIRBFT专用气囊:
Airbft airbag:
