查看: 651|回复: 0
丰田坦途空气悬挂套件拖挂房车利器已开工现货秒发
发表于 2021-3-27 16:37:32 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Toyota Tantu air suspension kit Trailer sharp tool has been started, spot second hair
丰田坦途(丰田Tundra)是一款日本丰田公司生产的美版的大皮卡,其大小可以和悍马不差上下。这款车主要在北美销售,国内进口少量。
很适合长途旅行的代步工具,它受到一度追捧的原因在于它的多功能性--集合了SUV的越野性能、卡车的载货能力、以及轿车的舒适性。
Toyota tundra is a large pickup truck made by Toyota in Japan, which is the same size as Hummer. The car is mainly sold in North America, with a small amount of domestic imports.
It is very suitable for long-distance travel. The reason why it was once popular is its versatility, which combines the off-road performance of SUV, the carrying capacity of truck and the comfort of car.
皮卡的用途可以非常多样化,首先满足普通的乘用所需,然而关键的还是装载各种货物,甚至在后面拖曳着一艘游艇或者房车。如此看来,皮卡是日常生活中的能手, 而作为皮卡中的佼佼者丰田坦途,也是拖曳、载货的好手,为了更大地提升坦途的拉货能力,可为它的后悬挂换上气动避震,矫正前后悬挂的高度差,或者在特定的情况下降低或升高后悬挂的高度,让坦途的装载能力更强悍。说到气动避震, 下面这辆坦途改装AIRBFT气动避震,一万公里路试凯旋归来,无论是高原还是冰川,无论是戈壁还是沙漠都无法阻挡,畅通无阻。
Pickups can be used for a variety of purposes. First of all, they can meet the needs of ordinary passengers. However, the key is to load all kinds of goods, and even drag a yacht or RV behind. In this way, pickup truck is an expert in daily life. As a leader in pickup truck, Toyota Tantu is also a good hand in towing and loading. In order to greatly improve Tantu's ability to pull goods, we can replace its rear suspension with pneumatic shock absorbers, correct the height difference between the front and rear suspension, or reduce or increase the height of the rear suspension under specific circumstances, so as to make Tantu's loading capacity stronger. When it comes to pneumatic shock absorbers, the following flat road vehicle is refitted with airbft pneumatic shock absorbers. After a 10000 kilometer road test, it is unstoppable and unimpeded no matter whether it is plateau or glacier, Gobi or desert.
上面说了4点好处,其实啊,大多数车友是为了更好的趴低……车子低了对我们来说才是美,才有范儿。
还能够享受周围人们的注目,也是一件极其满足虚荣心的事情。
There are four advantages mentioned above. In fact, most of the riders want to get down better Only when the car is low can we have beauty and style.
It is also a matter of great vanity to enjoy the attention of the people around you.
