查看: 626|回复: 0
大众尚酷AIRBFT气动避震完工三段记忆功能手机APP遥控升降随心
发表于 2021-3-27 16:18:23 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Volkswagen Shangku airbft pneumatic shock absorbers complete three memory functions
尚酷,英文名称Scirocco,拥有前卫动感的设计,被誉为“大众汽车有史以来最具动感”的双门跑车,是一辆全天候高性能跑车,2010年4月9日于上海上市.
尚酷驱动方式为前轮驱动,制动方式为通风盘式,引擎为L型4缸2.0升燃油直喷式,提供“运动版”和“豪华版”两个车型供消费者选择。
Shangku, English name Scirocco, with avant-garde dynamic design, is known as "the most dynamic two door sports car in the history of Volkswagen". It is an all-weather high-performance sports car. It was launched in Shanghai on April 9, 2010
Shangku's driving mode is front wheel drive, braking mode is ventilated disc, engine is L-type 4-cylinder 2.0L fuel direct injection, and two models of "sports version" and "luxury version" are provided for consumers to choose.
改装是每一个玩车人都必经一个阶段,原厂件虽然耐用但是美观程度却不行,所以所外观姿态比较讲究的玩家就会对车子进行改装,就出现了很多的改装风格,比如:VIP、Hellaflush等。今天我们来欣赏大众尚酷改装AIRBFT气动避震悬挂的低趴风格,只改了减震效果不是很好,期待更换轮毂数据的完美姿态!
Refitting is a necessary stage for every car player. Although the original parts are durable, they are not beautiful enough. Therefore, players who pay more attention to the appearance and posture will refit the car, and there are many refitting styles, such as VIP, hellaflush and so on. Today, we're going to appreciate the low lying style of the airbft pneumatic suspension modified by Volkswagen Shangku. Only the shock absorption effect is not very good. We're looking forward to the perfect posture of changing the hub data!
正所谓一低遮百丑,这几年HF改装火遍大街小巷,气动减震也是一夜变身改装界网红
As the saying goes, "one low covers all the ugly things." in recent years, HF refitting has become popular all over the streets, and pneumatic shock absorbers have become popular in refitting industry overnight
So what is it? In fact, it is a device that can control the air pressure and change the height of the car. It is similar to the legendary active body control system (ABC), but its working medium is gas. Generally speaking, it is a set of things as shown in the figure below, including elastic rubber airbag shock absorber, air pressure control system, trunk air tank and electronic control system. It is actually similar to air shock absorber The principle is very similar to the common shock absorber, coil spring + shock absorber, except that by changing the volume of the air chamber (up and down direction), the distance between the car body and the ground can be adjusted, and the soft and hard characteristics can be changed to a certain extent. In addition, the size of the vent hole of the shock absorber can be changed by the motor, so as to adjust the damping force of the shock absorber. Therefore, the air shock absorber can often provide better performance Performance, huh! That's the confidence
