查看: 767|回复: 0
无改装 不野马 福特野马改装气动避震低姿态精品案例分享
发表于 2021-3-27 13:53:36 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
No refitting, no Mustang Ford Mustang refitting pneumatic shock absorber low profile boutique case sharing
由于Mustang I野马概念车的两座设计实用性太低,被福特高层驳回后,1963年10月,福特推出了Mustang II概念车,将布局改为了发动机前置,并采用四座布局。1964年4月17日,经过福特团队反复论证、修改后的第一代量产版Mustang于纽约世博会上正式发布,野马自此正式向全世界展示了它的风范,在刚推出时的价格为:2368美元。福特的时间表把握得非常之巧,此时正值战后生育高峰期的一代刚刚进入购车的年龄,这一代人对车的要求与其父母大相径庭,他们想张扬自己的个性,野马应运而生。
Due to the low practicability of Mustang I Mustang concept car's two seat design, it was rejected by Ford's senior management. In October 1963, Ford launched Mustang II concept car, which changed the layout to front engine and adopted four seat layout. On April 17, 1964, the first mass production version of Mustang was officially released at the New York World Expo after being repeatedly demonstrated and modified by the Ford team. Since then, Mustang has officially demonstrated its style to the whole world. When it was first launched, the price was $2368. Ford's schedule is very skillful. At this time, the generation of the postwar baby boom has just entered the age of buying a car. This generation's requirements for cars are very different from their parents. They want to publicize their personality, and Mustang emerges as the times require.
现在在路上我们会经常见到一些车子降的很低来开,看起来效果很不错,这种效果都是改装了气动避震悬挂。气动避震和原车空气悬挂是由一些区别的,主要是针对的使用效果不同。气动避震主要就是玩低趴,追求姿态的魅力!是年轻人喜欢的风格。今天给大家分享福特野马改装AIRBFT气动避震悬挂的魅力!
Now on the road, we often see some cars driving very low. It seems that the effect is very good. This effect is refitted with pneumatic suspension. There are some differences between the pneumatic shock absorber and the original air suspension, mainly for the different use effect. Pneumatic shock absorber is mainly to play low lying, the pursuit of the charm of posture! It's a style young people like. Today I would like to share with you the charm of Ford Mustang refitting airbft pneumatic suspension!
