查看: 598|回复: 0
Airbft铝合金储气罐到货旋压成型杜绝焊接漏气的烦恼专业高压检测设备抽检
发表于 2021-3-27 13:19:34 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Airbft aluminum alloy gas tank arrival spinning forming to eliminate the trouble of welding leakage
6: Simple operation, easy installation.
A good pneumatic shock absorber brand, that is a high-quality manufacturers, a complete quality assurance after-sales service system, product market share, market reputation, market feedback! Responsible installation and modification shop, handling every detail, checking before delivery, air leakage, loose abnormal noise, damping height! Before refitting, what you need, how you want to play, whether you want the effect after installation, and whether you have the convenience in the process of use
