查看: 588|回复: 0
劳恩斯BH安装AIRBFT气动避震悬挂 低调奢华姿态
发表于 2021-3-26 16:01:58 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Lounes BH installed airbft pneumatic suspension, low profile luxury posture
劳恩斯(Rohens)是现代汽车旗下高端品牌第一款车系,打破了延续20多年的前置发动机、前轮驱动汽车结构,采用后轮驱动方式,前后轴载荷比达到了最理想的重量分配,从而达到最小的转弯半径和机动性。
Rohens is the first series of Hyundai's high-end brand. It breaks the front engine and front wheel drive structure that has lasted for more than 20 years. It adopts rear wheel drive mode, and the front and rear axle load ratio achieves the optimal weight distribution, so as to achieve the minimum turning half diameter and mobility.
现代劳恩斯品牌是现在汽车旗下的一个高端轿车品牌,在国内可能我们见得不多,因为是韩国进口车型价格有太高,所以在中国的市场确实很少,今天我们分享的这辆劳恩斯BH改装气动避震案例是来自韩国玩家分享的,安装AIRBFT空气悬挂套件,低姿态魅力引领潮流!
Hyundai lawns brand is now a high-end car brand under the auto company. Maybe we don't see much in China, because the price of imported models from South Korea is too high, so it's really rare in China's market. Today, we share this case of lawns BH refitting pneumatic shock absorbers from South Korean players. With the installation of airbft air suspension kit, the low-profile charm leads the trend!
低姿态改装是一种很美的改装效果,要想让车子趴地又不影响日常的使用,就需要一套空气避震悬挂,顾名思义,空气避震通过空气气囊进行减震的,主要通过对气囊的充放气来调节车身高度,充气可以升高车身,正常行驶,没有空气车子就可以实现低趴的效果!来看看现代劳恩斯空气避震改装的低趴风格!
Low profile refitting is a beautiful refitting effect. If you want to make the car lie on the ground without affecting the daily use, you need a set of air shock absorber suspension. As the name suggests, the air shock absorber uses the air bag to reduce the shock, mainly through the inflation and deflation of the air bag to adjust the height of the car body. Inflation can raise the car body and drive normally. Without air, the car can achieve the low profile effect! Take a look at the low lying style of modern lounes air shock absorbers!
话说这是个什么东西呢?它其实是一套可以控制气压改变车身高低的装置,与传说中的主动车身控制系统(ABC)类似不过它的工作介质是气体,一般来说就是下图所示的这么一套家伙事,其中包括弹性橡胶气囊减震器,气压控制系统、后备箱储气罐及电子控制系统等,它其实和空气减震的原理与常见减震器,螺旋弹簧+减震筒形式原理十分类似,只不过通过改变气室体积(上下方向),来调整车身离地距离并一定程度改变软硬特性,另外减震筒部分则可以由电机改变通气孔尺寸,从而调节减震器的衰减力,因此空气减震器往往能提供更好的性能表现,嗯!就是这么自信!
So what is it? In fact, it is a device that can control the air pressure to change the height of the car, similar to the legendary active body control system (ABC), but its working medium is gas. Generally speaking, it is a set of things as shown in the figure below, including elastic rubber airbag shock absorber, air pressure control system, trunk air tank and electronic control system, In fact, the principle of air shock absorption is very similar to that of common shock absorbers, such as coil spring and shock absorber cylinder. Only by changing the volume of the air chamber (up and down direction), the distance between the car body and the ground and the soft and hard characteristics can be adjusted to a certain extent. In addition, the size of the air vent of the shock absorber cylinder can be changed by the motor, so as to adjust the damping force of the shock absorber, So air shock absorbers tend to provide better performance, eh! So confident!
