查看: 583|回复: 0
被人遗忘的老车桑塔纳旅行改装气动避震容光焕发
发表于 2021-3-26 15:42:47 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Forgotten old car Santana travel refitted pneumatic shock absorber radiant
在90年代,桑塔纳盛行的年代,许多人以拥有一辆桑塔纳为荣,当时有一辆桑塔纳比现在拥有一辆宝马还稀罕,而桑塔纳在1992年推出了桑塔纳旅行版,凭借着桑塔纳的影响,桑塔纳旅行车也是十分受欢迎,一推出就被许多政府机构采购当成公用车,因为它的空间大,而且有着桑塔纳的耐用性,被当做工具用车使用,今天为大家分享桑塔纳旅行改装AIRBFT气动避震悬挂的魅力姿态。
In the 1990s, when Santana was popular, many people were proud to own a Santana. At that time, a Santana was rarer than a BMW now. Santana launched the Santana travel version in 1992. With the influence of Santana, Santana station wagon was also very popular. As soon as it was launched, it was purchased by many government agencies as a public car because of its large space It has the durability of Santana and is used as a vehicle tool. Today, I'd like to share with you the charming posture of Santana's refitting airbft pneumatic suspension.
AIRBFT,相对于操控来说,那就它是一个四轮独立的水平记忆气动悬挂系统。何为四轮独立?就是相对于一些前后独立(我以前开始玩气动悬挂时就用过)的气动悬挂来说,就是每一个避震上的气囊都是单独一个电脑单元控制,单独的电磁阀控制,不会类似前后独立的系统一样两支避震的空气是流通的。这样就首先确保了每支避震确立了自己的独立工作,不会因为车身转向时的压力而把气压流通到不受压的避震气囊里面而产生一边高一边低的情况。水平记忆是一个气动悬挂系统的突破点,打破了老套的气压感应记忆,引入全新的,不会因为车辆载重之后导致记忆不准确的缺点,不管是高速过弯时车辆受力侧产生的压力还是载人后受重的情况下都可以稳定保持避震原先记忆的高度。
Airbft, relative to the control, is a four-wheel independent horizontal memory pneumatic suspension system. What is four rounds of independence? Compared with some front and rear independent pneumatic suspensions (which I used when I started playing pneumatic suspensions before), the air bag on each shock absorber is controlled by a separate computer unit and a separate solenoid valve, which is not the same as the front and rear independent systems. The air of the two shock absorbers is circulating. This first ensures that each shock absorber has established its own independent work, and will not flow the air pressure into the non pressurized shock absorber due to the pressure when the body turns, resulting in the situation of high side and low side. Horizontal memory is a breakthrough point of pneumatic suspension system, which breaks the old-fashioned air pressure induction memory and introduces a new one, which will not lead to inaccurate memory after the vehicle is loaded. Whether it is the pressure generated on the stressed side of the vehicle when cornering at high speed or the heavy load after carrying a person, it can stably maintain the original memory height of shock absorber.
