查看: 653|回复: 0
"拥有的不只是情怀"六代雅阁气动避震改装完美低趴姿态!
发表于 2021-3-26 15:26:12 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
"Have more than feelings" six generation Accord pneumatic shock absorber refitted perfect low prone posture!
对于一些已经十几年的老车,想要好好的玩不花费一些时间和金钱是肯定不行的,玩老车第一步就是翻新,由内而外的检查, 接下来就是改装,想要老车有范外观姿态不能少,低趴改装是最显效果的,所以现在很多玩老车的第一步就是改装气动避震悬挂,让车子趴下来!这台上了年纪的六代雅阁 ,经过气动避震的改装,重新绽放出于总不同的HF低趴风格!
For some old cars that have been used for more than ten years, it's definitely impossible to have a good play without spending some time and money. The first step to play with old cars is to renovate them and check them from the inside out, The next step is refitting. If you want an old car to have a good appearance and posture, you can't do less. Low lying refitting is the most effective, so now the first step for many old cars is refitting the pneumatic suspension to make the car lie down! This six generation old Accord, after the modification of pneumatic shock absorbers, re blooming out of the total different HF low lying style!
HellaFlush的主要特征:
Hellaflush has become an international appearance trend of refitted cars. With the development and progress of domestic refitted cars, more and more people accept it. HF model has become a symbol of taste
The main features of hellaflush are as follows:
1. The central idea of hellaflush is offset is everything. The wheel hub uses an offset value that is more stretched than the normal value, so that the wheel hub is beyond the coverage of the body fender.
2. The distance between the wheel eyebrow and the wheel hub should be as small as possible. To complete this task, the car body should be lowered to a height that does not conform to the daily use, so that some HF style cars can't drive at all, so they have to use a trailer to pull the orz. As for how to lower the car body, there is no standard. Pneumatic shock absorbers, twisted teeth shock absorbers, short springs, or even modified sheep horns, you can do anything to achieve your goal.
3. As a result of the first two points, if the tire wants not to be rubbed and burst by the fender, it must use a specification narrower than the width of the wheel hub, so that the edge of the tire can be retracted so that it can be completely hidden in the fender. Of course, the fender can also be rolled in or expanded to a certain extent according to the protruding degree of the wheel hub.
4. If you want to have more attitude than attitude, you can't take the normal road for the inclination value of the tire. Take off at minus 2 degrees (that is, the upper part of the track is narrow and the lower part is wide). The method can be to adjust the inclination rocker arm, gasket and change the sheep's horn. In a word, we can't see eye to eye with normal people.
5. Tire stretch refers to the effect of the narrow tire installed on the ultra wide wheel hub. It's not easy to achieve this effect. Choosing a variety of tires should be strictly calculated according to the width of the wheel hub. Because, too wide hub with a narrow tire, when the tire inflation may dislocation, so can let the tire according to the correct position taut on the hub depends on the technician's modification level.
