查看: 633|回复: 0
享受低姿态 宝马4系轿跑改装气动避震悬挂的魅力
发表于 2021-3-26 15:04:51 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Enjoy the charm of low profile BMW 4-series car modified with pneumatic suspension
BMW 4系列(德语:BMW 4er)是德国汽车制造商BMW所生产的一个中级车系,自2013年10月5日起以轿跑车型(F32)上市,其目的是将既有的3系轿跑车替换为全新的4系,以进一步区分更具运动性的轿跑车。该系列的概念于2012年12月在慕尼黑首次向公众发布,并在次年1月的底特律车展率先亮相。其后配备有硬顶折叠敞篷的敞篷版(F33)于2014年3月8日推出市场。而融合了敞篷和轿跑元素的高级轿跑车(F36)则可用作配备汽油发动机的428i、428i xDrive和435i,以及柴油发动机的420d。
BMW 4 series (German: BMW 4er) is an intermediate car series produced by BMW, a German automobile manufacturer. Since October 5, 2013, it has been launched as a sedan car (F32). Its purpose is to replace the existing 3-series coupe with a new 4-series coupe, so as to further distinguish the more sporty Coupe. The concept of the series was first released to the public in Munich in December 2012 and was first unveiled at the Detroit auto show in January of the following year. Subsequently, the convertible version (f33) with the hardtop folding convertible was launched on March 8, 2014. The advanced coupe (f36), which combines open top and car elements, can be used as 428i, 428i xDrive and 435i with gasoline engine, and 420D with diesel engine.
低姿态改装是目前的一个潮流,不管是国内还是国外都有改装群体在玩,今天我们来看看改装AIRBFT气动悬挂的宝马4系姿态效果,一低遮百丑,不是说说这么简单!
Low profile refitting is a trend at present. There are refitting groups at home and abroad. Today, let's take a look at the attitude effect of BMW 4 series refitted with airbft pneumatic suspension. One low cover one hundred ugly, not so simple!
The working principle of the shock absorber is mainly used to suppress the shock of spring rebound after shock absorption and the impact from the road. When passing through uneven road, although the shock absorption spring can filter the vibration of the road, the spring itself will have reciprocating motion, and the shock absorber is used to suppress the spring jump.
The types of shock absorbers are divided from the angle of producing damping materials. There are mainly two kinds of shock absorbers: hydraulic shock absorbers and pneumatic shock absorbers.
