查看: 494|回复: 0
Toyota corolla改装气动避震 身临其境体验低趴飞速快感
发表于 2021-3-26 14:50:32 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Toyota Corolla modified pneumatic shock absorber, immersive experience of low lying fast pleasure
花冠(COROLLA)是丰田汽车旗下的老牌产品,于1966年在日本下线,寓意“花中之冠”。1970年、1974年、1979年、1983年、1987年、1991年、1995年和2000年分别推出新一代花冠,已经是第9代车型。
丰田花冠全球累计销量超过3600万辆,达成单一品牌累计销量总冠军。第九代花冠(Corolla EX)由一汽丰田生产,是丰田国产车型中首款采用VVT-i发动机的车型。丰田第10代COROLLA轿车将中文名从“花冠”改为“卡罗拉”。
Corolla is an old brand product of Toyota, which was launched in Japan in 1966, implying "crown of flowers". A new generation of corolla was launched in 1970, 1974, 1979, 1983, 1987, 1991, 1995 and 2000 respectively. It is the ninth generation of corolla.
Toyota Corolla global cumulative sales of more than 36 million, a single brand cumulative sales champion. Corolla ex, produced by FAW Toyota, is the first domestic model of Toyota to adopt VVT-i engine. Toyota's 10th generation corolla changed its Chinese name from "corolla" to "corolla".
日常生活之中,很多人为了满足自己的喜好,不惜花费大量的人力财力。在汽车改装爱好者一族里,有很多的车友都想将自己的车子进行改装,有些想改装车子的高低,有的想改装车子的音响,有的想改装车子的动力性能,有的想改装车子的气动避震;而当下比较流行的一种改装就是气动避震,通过改装气动避震可以提高驾车的舒适性、安全性、稳定性,还可以实现四轮独立升降,四轮独立微调,前轮同时升降,后轮同时升降,四轮同时升降等功能。下面 主 为大家介绍一下丰田花冠改装AIRBFT气动避震的真实案例。
In daily life, many people spend a lot of human and financial resources in order to meet their preferences. Among the car refitting enthusiasts, many riders want to refit their cars, some want to refit the height of the car, some want to refit the car's audio, some want to refit the car's dynamic performance, some want to refit the car's pneumatic shock absorbers; and now a popular refitting is pneumatic shock absorbers, which can improve the comfort of driving It can also achieve four-wheel independent lifting, four-wheel independent fine-tuning, front wheel lifting at the same time, rear wheel lifting at the same time, four-wheel lifting and other functions. Here is a real case of Toyota Corolla refitting airbft pneumatic shock absorber.
气动避震的组成部分为控制系统和气动避震桶身两大类!
The components of pneumatic shock absorber are control system and pneumatic shock absorber barrel!
Intelligent air replenishment and intelligent adjustment of car level: in fact, the functions of these two functions are probably the same. For example, when the car body is originally horizontal, a fat person sits in the rear seat, the height of the rear side will be reduced. At this time, the computer will detect the height change of the rear side, and will react in less than a second. The two rear airbags will inflate to maintain the height Body level!
The ignition will automatically rise to the set position height: such a function is that no matter what height you park, for example, the lowest or the highest, when you stop, get off and drive again, the system will automatically raise the car to the second gear position, that is, the normal car height! This has both advantages and disadvantages. For example, the road condition is very bad. There is no suitable parking space. When you park, you stop at the highest position. When you drive again, the system will automatically reduce. If you just park on a very high rural cement deceleration belt, it is very likely or direct bottoming! The advantage is that in a normal parking lot, the car stops to the lowest level. When you drive again, the train will automatically rise to the normal driving height at one o'clock. Think about how high the driving height is
One key to the lowest: a key, you can reduce the car to the lowest state! On the control panel, there is a one button to lower. Long press for 3 seconds, and the whole car will be in the lowest state! Why three seconds? Because this is to prevent misoperation. If your car is running, it's a terrible thing if a child or a special case accidentally touches the button with one button lowered. This design can completely avoid this situation. It doesn't matter if you accidentally touch all the buttons, as long as you don't press them for a long time!
