查看: 549|回复: 0
斯巴鲁翼豹STI空气悬挂气动避震改装低趴文化演绎低趴美学
发表于 2021-3-25 15:37:13 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Subaru leopard STI air suspension pneumatic shock absorption refit low lying culture deduces low lying Aesthetics
斯巴鲁STi依然只是属于少数人的运动利器,体现的是一种完全自主的操控乐趣,它不是Golf GTI,但也许有一天,配备了双离合自动变速器的STi,也能令更多人体会到左右对称全时四轮驱动系统和水平对置发动机的乐趣。
Subaru STI is still only a sport tool for a few people, which embodies a completely autonomous control pleasure. It is not Golf GTI, but maybe one day, STI equipped with dual clutch automatic transmission can make more people realize the fun of left-right symmetrical all-time four-wheel drive system and horizontally opposed engine.
其实说来话长,要讲斯巴鲁翼豹STi的光辉业绩和车系历史估计三天三夜都说不完,就以一个国际性的WRC比赛中,翼豹STi的表现称得上是一部惊险又刺激的好莱坞大片,其魅力之大。下面请欣赏改装AIRBFT气动低趴后的效果。
In fact, it's a long story. It's estimated that the brilliant achievements and the history of the car series of Subaru leopard STI can't be finished in three days and three nights. In an international WRC competition, the performance of the leopard STI can be regarded as a thrilling and exciting Hollywood blockbuster with great charm. Now please enjoy the effect of refitting airbft pneumatic low prone.
The installation of pneumatic shock absorber will link a control remote controller in the car. You can set several gears according to your own requirements. You can quickly switch between a variety of heights. In this way, you can make the car "lie down" on the ground when parking and rise to the normal driving height when driving normally.
The working principle of the pneumatic shock absorber is to change the height of the car by controlling the air pressure, which includes the cutter shock absorber, the air pressure control system and the electronic control system. Many of us don't worry when we're at the car show.
