查看: 634|回复: 0
捷豹XJ8改装气动避震完美低趴展现最美身姿
发表于 2021-3-25 15:06:29 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Jaguar XJ8 modified pneumatic shock absorbers, perfect low prone, showing the most beautiful posture
捷豹XJ是捷豹轿车的一款顶级产品,XJ采用了具有宽阔腰线及短捷有力的车尾,比例紧凑,倾斜的前挡风玻璃和后窗玻璃为XJ增添了运动气息,和谐而纯正;XJ的内饰做工出色,突出了驾乘舒适性;后排头部和腿部有充足的活动空间。
大气的中控台设计展现出了浓重的英式风格,按键虽然繁琐却有很高的实用价值。动力部分,捷豹XJ完全继承了其品牌的传统。车身和底盘极少受到路面不平的影响,很是平稳。之所以XJ能有这样突出的表现,主要是由于四只车轮均采用了空气弹簧,并且拥有两种特性的减震器和重量较轻的后桥。
The XJ is one of the top products of the Jaguar car. The XJ has a wide waistline, a short and powerful tail, a compact proportion, a sloping front windshield and rear window, which add a sense of movement to the XJ, harmonious and pure; the interior of the XJ is excellent, highlighting the driving comfort; there is sufficient space for the head and legs of the rear row.
The design of the center console shows a strong British style. Although the buttons are cumbersome, they have high practical value. In terms of power, the Jaguar XJ has completely inherited the tradition of its brand. The car body and chassis are rarely affected by the uneven road surface and are very smooth. The reason why XJ has such outstanding performance is that all four wheels adopt air springs, and have two kinds of shock absorbers and light rear axle.
改装有喜欢玩新车的,有喜欢玩经典老车的,不能说那个更好,只能说都有自己的追求和梦想,今天我们来欣赏经典车型捷豹XJ8改装AIRBFT气动避震悬挂的低趴案例,经典的设计搭配低姿态真是绝配!
There are those who like to play with new cars and those who like to play with classic old cars. We can only say that they all have their own pursuit and dream. Today, let's enjoy the low lying case of the classic model Jaguar XJ8 modified with airbft pneumatic suspension. The classic design with low attitude is a perfect match!
3: Responsible installation and modification shop, handling every detail, checking before delivery, air leakage, loose abnormal noise, damping height!
4: Before refitting, what you need, how you want to play, whether you want the effect after installation, and whether you have the convenience in the process of use
