查看: 615|回复: 0
BMW 3series G20低姿态改装 AIRBFT气动避震魅力打造帅气有型
发表于 2021-3-25 14:16:31 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
BMW 3series G20 low profile modified airbft pneumatic shock absorption charm to create a handsome look
BMW 3series G20整车车身进行了全面放大,长宽高三维数据达到了4709*1827*1442mm,轴距为2851mm,无论是车体轴距还是内部空间,都有了一定程度的提升。全身设计让它能显著改善气流和气动外形。改装气动避震悬挂效果更是达到完美姿态,一起来欣赏改装AIRBFT气动避震低姿态的宝马G20有多美!
The body of BMW 3series G20 has been fully enlarged. The three-dimensional data of length, width and height have reached 4709 * 1827 * 1442mm, and the wheelbase is 2851mm. Both the wheelbase and internal space of the car body have been improved to a certain extent. Full body design allows it to significantly improve airflow and aerodynamic shape. The effect of modified pneumatic suspension is even more perfect. Let's appreciate how beautiful the BMW G20 with modified airbft pneumatic suspension is!
在这个最求个性与时尚的年代,销量这么多,满大街的车 ,怎么样才能体现出自己的个性,显的与众不同?
上面说了4点好处,其实啊,大多数车友是为了更好的趴低……车子低了对我们来说才是美,才有范儿。
还能够享受周围人们的注目,也是一件极其满足虚荣心的事情。
In this age of personality and fashion, with so many sales and cars all over the street, how can you show your personality and make it different?
There are four advantages mentioned above. In fact, most of the riders want to get down better Only when the car is low can we have beauty and style.
It is also a matter of great vanity to enjoy the attention of the people around you.
The working principle of the shock absorber is mainly used to suppress the shock of spring rebound after shock absorption and the impact from the road. When passing through uneven road, although the shock absorption spring can filter the vibration of the road, the spring itself will have reciprocating motion, and the shock absorber is used to suppress the spring jump.
The types of shock absorbers are divided from the angle of producing damping materials. There are mainly two kinds of shock absorbers: hydraulic shock absorbers and pneumatic shock absorbers.
