查看: 605|回复: 0
丰田大霸王改装AIRBFT气动避震低姿态与时尚接轨
发表于 2021-3-24 16:15:49 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Toyota overlord refits airbft pneumatic shock absorber, low profile and fashion
丰田大霸王是丰田汽车生产的一款2.4 7人座标准版汽车,具有前驱驱动,油箱容积65升,参考价格46.88万-61万。
Toyota overlord is a 2.47-seater standard car produced by Toyota. It has a front drive, a 65 liter fuel tank and a reference price of 468800-610000.
现在国内的气动避震改装的氛围越来越好,可是还有很多想玩气动避震的但是还不是很了解,大体的来讲,现在的气动避震改装也就是分为两个版本,一种是基础版的,也就是入门级别的前后独立升降系统,另外一种是AIRBFT控制系统,也就是目前公认的最顶端的控制系统,包括稳定性和功能性都是相当的强大,很多人不是很了解前后独立升降和四轮独立升降到底有什么样的区别,还有实际应用中两者会产生什么样的差异,在这里就为大家简单的介绍一下……
Now the atmosphere of domestic pneumatic shock absorption modification is getting better and better, but there are still many people who want to play pneumatic shock absorption, but they don't know much about it. Generally speaking, the current pneumatic shock absorption modification is divided into two versions, one is the basic version, which is the entry-level front and rear independent lifting system, and the other is the airbft control system, which is currently recognized as the top control system The braking system, including stability and functionality, is very powerful. Many people don't know the difference between the front and rear independent lifting and the four-wheel independent lifting, and what kind of difference they will have in practical application. Here's a brief introduction
基础版的,也就是前后独立升降,还有一键整体下降,直白的来讲就是前边俩个轮子一起生活着事降,后边两个一起升降的,还有一键整体下降,相对于四轮独立升降的AIRBFT控制系统来说,存在的缺点就是在车子快速转弯时或者是车身载重分布不均匀的情况下,就会产生左右两边高度不一样的情况,因为左右气管是相通的,受力大的一边就会窜气到受压力小的那边去,所以选择基础版的一般都是比较轻的车型,重一点的车子不建议选择基础版
The basic version, that is, the front and rear independent lifting, has a one button overall drop. Frankly speaking, the front two wheels are living and falling together, the rear two wheels are lifting together, and the one button overall drop. Compared with the four-wheel independent lifting airbft control system, the disadvantage is that when the car is turning fast or the load distribution of the car body is uneven, it is easy to use The height of the left and right sides is not the same, because the left and right air pipes are connected, and the side with large force will blow to the side with small pressure, so the choice of the basic version is generally lighter, and it is not recommended to choose the basic version for the heavier car
AIRBFT,相对于操控来说,那就它是一个四轮独立的水平记忆气动悬挂系统。何为四轮独立?就是相对于一些前后独立(我以前开始玩气动悬挂时就用过)的气动悬挂来说,就是每一个避震上的气囊都是单独一个电脑单元控制,单独的电磁阀控制,不会类似前后独立的系统一样两支避震的空气是流通的。这样就首先确保了每支避震确立了自己的独立工作,不会因为车身转向时的压力而把气压流通到不受压的避震气囊里面而产生一边高一边低的情况。水平记忆是一个气动悬挂系统的突破点,打破了老套的气压感应记忆,引入全新的,不会因为车辆载重之后导致记忆不准确的缺点,不管是高速过弯时车辆受力侧产生的压力还是载人后受重的情况下都可以稳定保持避震原先记忆的高度。
Airbft, relative to the control, is a four-wheel independent horizontal memory pneumatic suspension system. What is four rounds of independence? Compared with some front and rear independent pneumatic suspensions (which I used when I started playing pneumatic suspensions before), the air bag on each shock absorber is controlled by a separate computer unit and a separate solenoid valve, which is not the same as the front and rear independent systems. The air of the two shock absorbers is circulating. This first ensures that each shock absorber has established its own independent work, and will not flow the air pressure into the non pressurized shock absorber due to the pressure when the body turns, resulting in the situation of high side and low side. Horizontal memory is a breakthrough point of pneumatic suspension system, which breaks the old-fashioned air pressure induction memory and introduces a new one, which will not lead to inaccurate memory after the vehicle is loaded. Whether it is the pressure generated on the stressed side of the vehicle when cornering at high speed or the heavy load after carrying a person, it can stably maintain the original memory height of shock absorber.
