查看: 578|回复: 0
宝马G20低姿态改装 AIRBFT气动避震魅力打造
发表于 2021-3-24 15:36:11 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
BMW G20 low profile modified airbft pneumatic shock absorber to create Charm
宝马G20整车车身进行了全面放大, 全身设计让它能显著改善气流和气动外形。改装气动避震悬挂效果更是达到完美姿态,一起来欣赏改装AIRBFT气动避震低姿态的宝马G20有多美!
The BMW G20 vehicle body has been fully enlarged and designed to significantly improve the airflow and aerodynamic shape. The effect of modified pneumatic suspension is even more perfect. Let's appreciate how beautiful the BMW G20 with modified airbft pneumatic suspension is!
In recent years, one low cover three ugly is a sentence that riders often talk about, and Hella flush is a modified style that deduces this sentence to the extreme. In the hellaflush style refitted car, in addition to the J value, et value of the wheel hub and exaggerated camper and other parameters, the remaining important problem is to reduce the body. So many friends will directly choose the tooth suspension, because the tooth suspension can not only reduce the body height, but also provide sufficient support for the vehicle, which is very popular with many riders. However, for Hella flush's ultimate players, the twisted tooth shock absorbers have long been unable to meet their "low" needs, so pneumatic shock absorbers (inflatable shock absorbers) have won the hearts of these ultimate players with their flexible ability
HellaFlush的主要特征:
The main features of hellaflush are as follows:
1. The central idea of hellaflush is offset is everything. The wheel hub uses an offset value that is more stretched than the normal value, so that the wheel hub is beyond the coverage of the body fender.
2. The distance between the wheel eyebrow and the wheel hub should be as small as possible. To complete this task, the car body should be lowered to a height that does not conform to the daily use, so that some HF style cars can't drive at all, so they have to use a trailer to pull the orz. As for how to lower the car body, there is no standard. Pneumatic shock absorbers, twisted teeth shock absorbers, short springs, or even modified sheep horns, you can do anything to achieve your goal.
3. As a result of the first two points, if the tire wants not to be rubbed and burst by the fender, it must use a specification narrower than the width of the wheel hub, so that the edge of the tire can be retracted so that it can be completely hidden in the fender. Of course, the fender can also be rolled in or expanded to a certain extent according to the protruding degree of the wheel hub.
If the inclination of the wheel is narrower than the normal, you can also adjust the take-off angle. In a word, we can't see eye to eye with normal people.
5. Tire stretch refers to the effect of the narrow tire installed on the ultra wide wheel hub. It's not easy to achieve this effect. Choosing a variety of tires should be strictly calculated according to the width of the wheel hub. Because, too wide hub with a narrow tire, when the tire inflation may dislocation, so can let the tire according to the correct position taut on the hub depends on the technician's modification level.
